3,868
1,120
Hi,new to the forum, i picked up this rover lawn mower non goer,had been sitting for a long time.it had spark and compression i pulled down carby(flo jet) and found stale fuel and gumed up. Fuel tank was same.so cleaned up both.engine now running. There was no decals on the mower to indicate what size/type the engine is. Numbers stamped on engine cover are 121702 018501 91072956,hoping someone can give me more info on this engine Thanks ps went to file manager to add photo just wasn't working for me
Posts: 1,548 Likes: 25
its manufactured July 29, 1991. HP was around 4.5 but Briggs didn't post those specs.
SKU 121702-0185-01 Technical Specifications Model Series 1217 Engine Series 600 Displacement 205 Oil Capacity 20 oz (0.6 l) Valve Configuration L-head Flywheel Torque 55 lb/ft (74.5 Nm) Governor Arm Torque 40 lb/in (4.5 Nm) Carb Mount 40 lb/in (4.5 Nm) Plug Gap 0.02 in (0.50 mm) Intake Valve .005-.007 in (.13-.18 mm) Exhaust Valve .007-.009 in (.18-.23 mm) Idle Speed 1750 Air Gap .006-.010 in (.15-.25 mm) Flywheel Puller Part 19069 Flywheel Holder Part 19433 Connecting Rod Torque 100 lb/in (11.5 Nm) Sump Torque 85 lb/in (9.5 Nm) Head Torque 140 lb/in (16.0 N
G'day AVB, Thank you for your reply, the info is most useful, one other thing you may be able to answer, when i was working on this motor i noticed i could move the fly wheel up and down how much end play is acceptable on these motors?
Per service manual it is .002 – .030” (0.05 – 0.76 mm) for 120000 series side valve engines. Now there are shims that could be used when the play was excessive.
• 220624 .0625 thrust washer for .875” (22.23 mm) dia. crankshaft. • 220708 .0625 thrust washer for 1.000” (25.4 mm) dia. crankshaft. • 222949 .062 thrust washer for 1.181” (30.0 mm) dia. crankshaft. • 222951 .062 thrust washer for 1.378” (35.0 mm) dia. crankshaft
Topics12,730
Posts106,679
Members17,977
