3 members (AMP, Bumps, MowingManiac), 1,806 guests, and 997 robots.
by Bumps - 30/05/26 12:23 PM
Greenfield Javelin Mk2
by Beefy - 21/05/26 06:22 PM
GX25 Honda
by NormK - 21/05/26 12:33 PM
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
by Bumps - 02/06/26 02:59 PM
by monala - 29/05/26 12:24 PM
by Bumps - 28/05/26 12:36 PM
GX25 Honda
by NormK - 22/05/26 08:25 AM
Sanli height adjustment knob
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
Can anyone suggest a supplier for a new big end bearing for VC 160 2-stroke late 1970's?
The size data is shown on the accompanying photos.
I've looked everywhere but the only bearing that I can find is a fully encapsulated roller bearing which seems quite different to the separate roller system that I found once I slit the crank shaft.
KIND REGARDS TO ALL
- Bumps
Hi Bumps ,
You can use HK1616F - NTN or just get an old power torque motor and use the power torque alloy conrod and big end bearing.
https://outdoorking-forum.com.au/forum/ubbthreads.php/topics/119997/victa-full-crank-engines.html
I did see one in Aus for $11. but was just one of the first ones I looked at. https://au.rs-online.com/web/p/roller-bearings/0454749
Try your local bearing shop or just google online sales for HK1616F - NTN
Dear Max thx for your rapid reply but I cannot possibly see how the proposed bearing (HK1616F) would fit my application?
1. Bearing OD from your literature is quoted at 22 mm whilst the bore size on my con-rod is 27.61 mm - see attached photo
IE. Bearing OD is 4.4 mm undersize.
Q: Are you implying that I need to machine a sleeve and fit it to the con-rod big end bore to take up the gap?
2. Additionally, bearing diameter under the rollers from your literature is quoted at 16 mm whilst my crankpin diameter is 19.63 mm - see attached photo.
IE. Bearing is 3.6 mm undersize so the crank pin cant slide under the rollers.
Unless I'm missing something, I see cannot how the HK 1616F bearing would work in the big end application.
Any other ideas would be appreciated.
CHEERS+BEERS
- Bumps
Plenty of motors here if you want to grab a crank out of one
Been a while since I have needed to source bearings for obsolete machinery but suggest you take whatever bits you have to a bearings supply joint, and if they don't seem interested try another place.
One thing I discovered decades ago is that most bearing manufacturers may only make so-called sealed bearings and the part number may differ from the unsealed original but you can just get a sharp knife or pick and remove the seal/s.
Yes Bumps that bearing must fit the 125 cc and earlier 160 cc Victa, if yours is the later crank I would just use a second hand crank
that's has a good big end or swap a PT alloy rod and bearing. I wouldn't even get $40. these day for a serviced Victa PT mower.
I've seen Victa 2 strokes advertised for 2 years for $60. and they still can't sell them.
You are right there Max, all the stuff I have here will probably go to scrap, just not worth the effort
Thanks Chaps for your replies.
I would like to explore the viability of using a P.T rod in my old VC160 engine.
If one of you happens to have "on the shelf" access to an old P.T rod and big end bearing, I wonder if you would kindly measure and advise a couple of sizes for me?
1. Big end bearing inside diameter? ........... it must suit my my crank pin whose OD is 0.775 inches
2. Big bearing width (or conrod width)? ............ it be the same as my bearing width which is 0.500 inches so that the PT conrod fits between the crankshaft lobes and its thrust washers
ALTERNATIVELY, if anyone has an old P.T engine rod and bearing for sale or for giveaway, I'd be very pleased to receive it. Naturally, postage costs would be borne by me.
CHEERS+BEERS
- Bumps
Mattyh, Ashgren, Ludicr0us, eguatpatto, Jared.Ashby
17,980 Registered Users
Topics12,731
Posts106,686
Members17,981
