Hi everyone...would anybody out there happen to have a user and/or parts manual to suit a B&S Sprint 375?...(Rover chassis)..the numbers have not been stamped very well but they look like: Model 90902, Type 2091 and Code 04121052, can I tell when and where it was produced from these numbers?
Thanks all.
Posts: 1,548 Likes: 25
Well it was manufactured December 10, 2004. The 52 which get general production plant but I don't this as is not asked for much here in the States but someone here does as I have seen refered to before.
Posts: 1,842 Likes: 14
Yep that's the production date, as AVB says.
But the other numbers don't look to be correct - could the Model be 98902? And the Type should follow the format XXXX-XX; i.e. 6 digits in all.
Try rubbing a piece of chalk across the numbers, then wiping off the excess. This often makes them easier to read.
Cheers, Gadge
I've got a few 375 Sprints laying around in various conditions. If you end up needing a part give me a yell and I'll see if I have what you need.
Thanks fella's....there does appear to be an issue with the way the numbers have been stamped; very faintly, def only 5 numbers, it is possible that one digit is missing, I'll try the chalk trick, thanks Gadge...Paul_c, thanks but the B&S website wont recognize the numbers at this point in time. Thanks for the manufacturing date AVB. Trev, today I installed a carby kit, new plugs, air filter, oil and blades and the thing runs like new..thanks for your offer.
Probably going to be 09D902-2091-B1 base on type number and being a 09 series. Probably the "D" being misread as a Zero. No "098" with that type number.
Model numbers are sometime only 5 digit and we need to add the leading Zero. The six digit number comment was about the type number setup.
Posts: 988 Likes: 7
Putting that code into the Briggs engine manual search brings up the manual
https://www.briggsandstratton.com/us/en/support/manuals/results?NTT=09D902-2091*
Hope this is what you are after
Topics12,729
Posts106,672
Members17,966
