0 members (), 3,927 guests, and 1,458 robots.
Greenfield Javelin Mk2
by Beefy - 21/05/26 06:22 PM
GX25 Honda
by NormK - 21/05/26 12:33 PM
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
Sanli height adjustment knob
by NormK - 24/05/26 11:50 AM
GX25 Honda
by NormK - 22/05/26 08:25 AM
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
by Bumps - 09/05/26 01:34 PM
Hi, I am having an issue with my 450 series motor. It starts after using the primer but then stalls about 5 seconds later. The last time I used the mower it ran out of fuel. I have cleaned the spark plug to make so the connection is OK, but issue was not fixed. Please help.
Hi Aaron, welcome to Outdoorking.
When you run out of fuel, the engine sucks up whatever garbage is lying on the bottom of the fuel tank, and this often blocks up one of the filters in the carburetor. I think you will need to remove the fuel tank and carburetor from the engine, then remove the carburetor from the fuel tank. At that point you will be able to see both of the fuel filters. One is on the end of the long white plastic tube that reaches down to the bottom of the fuel tank. The other is a sort of a tubular mesh cover over the short, thick pickup tube. Please inspect both filters, and clean them with carburetor cleaner. Also clean out the shallow well in the top of the fuel tank, which the short pickup tube sucks fuel from. You should then inspect the main jet in the bottom of the short tube, and squirt some carburetor cleaner through it. Be very careful reassembling the carburetor to the fuel tank: the thin rubber diaphragm in between the two is fragile, and must be reinstalled exactly as it was to start with, on the same side of the gasket.
Please ask any necessary questions to have a clear understanding of what you are doing.
Norda, Gqpatrol, kdog, Zigstardust, Jezero
17,971 Registered Users
Topics12,729
Posts106,674
Members17,972
