13,050
799
this mower has started running almost flat out and doesn't respond to throttle control.should I look at removing carby and cleaning as there doesn't seem to be any other adjustments. Have cleaned out tank and tap seems OK, also checked hole in cap.Does anyone have manual for this model with plastic carby. thanks Keith
Posts: 5,427 Likes: 36
Keith, 1. Have you taken the starter off at any time? 2. Have you checked the 'O' ring on the cylinder where the carby mounts? 3. Have you checked the exhaust port for blockage? Check these first before we go any further. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Thanks Bruce will do, may take a few days. By the way have replaced starter rope and had to dismantle the whole engine and its just broken again. Keith
[This message has been edited by keithburg (edited 13 November 2005).]
Thanks Bruce will do,may take a few days.Have repaired broken rope by removing half the motor and has just broken again.(Will buy new rope this time) Keith
keithburg, Make sure that you replace the 'O' ring when you do the cord replacement. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Thanks once again Bruce, Have replaced starter o ring, carby manifold o ring (after 2 wrong sizes)and motor runs with a little adjustment but still not right. I couldn't remove exhaust, after removing top and bottom clips it was holding pretty tight and thought I might break it. regards, Keith
keithburg, I would suggest getting a new muffler and that would fix your problem. You should be able to get one on e-bay for a good price. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
once again Bruce thanks for your invaluable help. regards Keith
Topics12,729
Posts106,674
Members17,972
