2 members (NormK, looktall), 1,594 guests, and 1,032 robots.
GX25 Honda
by NormK - 21/05/26 12:33 PM
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
Sanli height adjustment knob
by Bumps - 28/04/26 05:22 PM
GX25 Honda
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
by NormK - 09/05/26 08:01 PM
by Bumps - 09/05/26 01:34 PM
by NormK - 07/05/26 10:15 AM
Hi,
"Inherited" an old Victa from my chiropractor, used it for about a year. Great mower because it always started with half a pull :-), but no catcher with it though.
Model details (printed on mower):
Pace - 160 Premier (Mark 2 - 70 series)
Based on some messages on this board, its got a metal carby (G3 I think) with the black governor sticking out the top). Very thick chassis compared to other 70 series I have seen. Has adjustable angle handles, using a plastic gear mating system.
Victa helpline reckons it is 1968-74, but they also recommended a CJ8 spark plug, when it's definitely a long plug. :-(
The last 2 times used, it started to sound bad so thought getting my old man to look over it and maybe a rebuild was a good idea.
Done so far/observed:
a. Cleaned about 3mm of dirt and oil from around the engine, could of been overheating.
b. Repaired hole in air snorkel tube, lots of crap stuck at entrance to carby.
c. Decompressor was not working, amazing is worked well enough to cut grass. Dad put in new gauze (old one decomposed) and reseated the valve, now works well.
d. Put back together, no start [Linked Image] Couldn't get a spark at all.
e. Pulled flywheel off, points fine and everything else looks 'ok'.
f. Dad pulled the cylinder off, turns out the piston's hole for the gudgeon pin was elongated about 1-2mm!!! Amazing it didn't sound like a jack hammer, maybe survived due to stuffed decompressor.
g. Conrod, bearing etc. all seem fine.
h. Finally got very small spark by touching lead against fins, not strong enough to jump spark plug gap.
i. Automatic cut-off switch from throttle doesn't work.
Questions:
1. What specific model would it be called? Any idea on which particular year it was made?
2. Does anyone have appropriate service/repair manuals for the engine, carby & actual mower? I assumed I would of found this info on the net, maybe at a Victa enthusiasts site, but couldn't find anything (nor a club site).
3. Need new piston and presumably, new cylinder as well, does that sound right?
4. Any ideas on the spark issue? Could it be a clapped out condenser? How do I check?
5. How to fix the cut-off switch not working?
6. Any idea on how to source a catcher? Other 70 series catchers are too wide, and it looks like the catcher attaches to the handle. Might be older than others.
Thanks in advance for any help you can send my way. I'd love to keep the old beast, it seems to be very well made, and would hate to get one of those flimsy new mowers.
BlueMM
Do you have an email address????// I can send you some pics or you can send me some if you have a Dig camera. Some of the good pace models had a catcher with wheels on and a fold up handle. Maybe one down at my junk heap . I will have a look for you next tim I go down. Just wrecked a side throw Pace yesterday/////////// Great fun wrecking after years of fixing LOL Joe
Joe
Blue,
I have sent you information on the G3 carby. In regards to the spark I would be replacing both the points & condensor. The cylinder & piston we can supply as well as points etc.
On the air filter housing you should find a sticker let me know the numbers on it.
The information that I have sent you should help with the cut-off problem. Just make sure you look at everything especially where the cut-off wire goes.
You can send me pictures just by clicking on moderator.
Bruce [Linked Image]
Thanks Guys,
Joe: My email is bluemm1975-bb_AT_yahoo.com (replace _AT_ with @). I'll get my Dad to take a photo, since it is at his place (about 30 minutes from you). What's your email so I can send? My brother has a friend (~26) who has the peach can Victa, who lives in Sale as well.
Bruce, thanks for the G3 pdf. Hopefully I can get the switch working again [Linked Image]
I'll get Dad to find the number on the filter, and I'll forward you a photo.
Do you have any pdf's on servicing the electrics and/or engine?
Cheers, BlueMM
Hi Blue I just typed in your address to send email but it was rejected My email is niteglo@vic.australis.com.au so if you email me I can copy your addres out Regards Joe
Joe
Hi Joe & Bruce,
There was no model number (or any remains of) on the air filter. Dad took some photos of it, without the engine since it's in the shed on a engine stand. Photos were a little big to send through email, so I uploaded them to http://bluemm.blogspot.com/2005/10/victa-pace-160-premier-mower.html
By clicking on each image, you can see it in its full size.
blue,
The spark plug that you require is a chapion N21. The grass catcher to suit your machine is model 17. As to the year it would be hard without the Model number which starts with the letter V. If I have that I can tell you the year it was made.
Hi Blue. I had a look at the pics on the Blogg Site, Very good quality pics. i must look into that side of computering. The mower has the look of a Store brand to me . I will have a look around my junkyard and seeif there is anything like it . The catcher I am sure fits on to the white plastic sleeve and that what gives the impression of a Storebrand model Regards Joe
Joe
Bruce:
Thanks about the spark plug & especially the catcher, at least I now have something to ask about [Linked Image] You wouldn't know of a good way to locate a No.17??
Are there any reference books around that I could lookup to try and track down the model num of the mower??
Dad's starting to put the engine back together, do you have any PDF's on service/repair of the 160 engine??
Thanks for all your help, very much appreciated.
Joe:
Pics are all Dad's doing, can't take any credit for that one. But I did add it to the Blog, which took all of about 6 clicks and a bit of typing.
Yeah, the catcher fitting onto that white plastic sleeve sounds right to me, you wouldn't have one in the "junkyard" by any chance?? Or a few tips on tracking one down??
When you say "Storebrand", do you mean like a department type store, as opposed to a Victa dealer??
Thanks guys, I'm sure I'll quit it with the 1000 questions soon enough [Linked Image]
[This message has been edited by blue (edited 14 October 2005).]
Hi Blue I have been quiet on the catcher as was not down the junkyard at all over the weekend and looks like Friday next now Regards Joe
Joe
Hi Blue sorry co catcher to suit your model and could not find a Pace Premier there at all. Prety sure your was a storebrand model.Storebrands were made in batches od so many and you could get your own firms name on them or they would be turned out to use up old components Did finf a Victa chassis with what looks to be mounting holes for a Villiers 7F engine but that will be another topic Joe
Joe
JOBPOF, nktapps, nglfm, KimmyGib, Midas
17,964 Registered Users
Topics12,728
Posts106,667
Members17,965
