I posted a question in this thread before realizing I was in the Briggs & Stratton section.
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/90584.html#Post90584My question is about Tecumseh engines so I decided to re-post the question here.
I purchased an ignition conversion module recently for a Kirby-Lauson VK-30. I have not been able to get it to work. Every now and then the engine fires, but it appears to be mis-firing. I have double-checked the timing and the armature is where it should be.
The module comes with a very basic diagram, showing positions for positive and negative ground.
![[Linked Image from bigcooter.com]](http://bigcooter.com/wp-content/uploads/2013/04/directions_1.jpg)
How do I find out if my engine is positive or negative ground?
I assumed these engines would all have to be negative ground, however I notice the "live" wire from the coil is covered in blue plastic, suggesting they must be positive earth. Also the wire to the stop switch is white with a red terminal, which also suggests positive earth.
So can anybody please tell me if these 1960s Kirby-Lauson engines were positive or negative earth? It is a very basic question but I can't find the answer in any of the manuals.
I have good spark on test, but could the timing be reversed if I've got the positive or negative the wrong way around? I am tempted to try it the other way, but thought I should ask first in case I damage the module. Perhaps I have already been using it the wrong way around??? I do not appear to have harmed the unit, as it is still firing, but I wonder if this is what's causing the firing sequence to be reversed?
