Posts: 580 Likes: 2
Hi, I have a friends chonda for repair. It's a "Tiger", rather small mower and I've never seen one before. The spark plug boot is broken. It screws off for easy replacement but I was wondering if I could replace it with a boot from an old Briggs and Stratton. The problem is that some of these boots have resistors built into them and I know the B&S boots don't. Is there a problem in doing this? Do the chonda's have resistors built into their spark plug boots? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/05/full-1794-28334-20160506_101602.jpg) Really bad photo, sorry. I answered my own question. Here are the components (that spark plug cap just unscrews). The order is boot, spring, resistor and cap, I have the spring in the wrong order in the photo. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/05/full-1794-28335-20160506_105243.jpg)
I've got a couple of dead Chondas lying around with good caps if new ones are too expensive. Be happy to cut one off and post it to you for the cost of the postage.
Posts: 580 Likes: 2
Thanks for the offer Aussietrev. I'm sure you'll be needing them for yourself as the magneto's are probably good. I'll dig one up somewhere. I was interested in the resistor part. I didn't know anything lived in there. Is it to stop voltage spikes and giving the spark plug a longer life?
Posts: 580 Likes: 2
Apparently it's just for noise suppression. It can be removed for stronger sparking and annoying neighbours listening to the radio.
Posts: 1,548 Likes: 25
If switching over to Briggs style boot just install a resistor spark plug of the correct heat range and you should be good to go. Don't forget the reach of the plug either.
Posts: 445 Likes: 1
Good thread with some good points.
AVB or anyone else,
Can you please clarify the need for a resistor spark plug of the correct heat range. I would like to make sure if I encounter the same problem as Sparker, that my machines are adjusted spot on.
Thank you
Peter
Posts: 580 Likes: 2
I just used the normal plug and a briggs boot. The resistor is only for b noise suppression whether it is on the boot or the plug
Posts: 8,188 Likes: 233
I haven't used resistor plug tops or resistor spark plugs in my old motorbikes or small engines for years and my neighbours have never complained about any interference with their tv or radios, and I'm sure my wife would have let me know if I was upsetting her tv from the front door at the top of her voice
Hey guys, Im in the same boat as OP. The spark plug boot on my Chonda also broke so I was planning on just replacing it with another.. which is about $10 on ebay.. but was wondering how easy it would be to just do a straight swap with a B&S or even VICTA boot ? I think I have an old boot here from a VC160. Is it just a matter of removing the boot and slipping the wire into the new one? or would have to cut/splice the new one into the existing cable ? Thanks
It not just as simple slipping on a boot as you got to install a new contact terminal for the switch over. Now there are contacts that are just a coiled wire that can be used in cases where you have a 45 degree entry or bendable contact. I have seen both available on net. There are also Crimp-on terminals. I would suggest whichever one that make this least vibration resistance. Personally I used the crimp terminals whenever I can but I have a professional installation tool for doing open barrel crimps.
If you look close at the first post's image and does take keen eyes you see that Honda boot was a 45. Now most Briggs are either 90 or 180 (Straight) boots and terminal. As far as the Victa someone on you end would need to chime in as I have never seen one. Second thing to keep in mind if installing a new style boot and terminal is the plug wire diameter as there are 5mm, 7mm, and even sometimes a 8mm use on some engines. 5mm are used on the handhelds and 7mm on most walk behind and riders here.
AVB, the Victa 2 strokes use the most primitive setup you could ever imagine, a small self tapper screwed into the end of the lead and a rubber boot slipped over it, but they work and that is all that matters
NormK, Now wait a minute are you saying just wrapping the wire around the plug terminal and using duct tape is high tech? I have seen that done here. I even seen a bar blade duct taped on a couple years ago. I figure you guys where doing things a little more professional including upgrading things like that when it needs repairing.
AVB, I give everything that leaves here a "lifetime" warranty, I point out that it is my lifetime, not the machines
Most customers I give a 30 day what I done only warranty. For those wanting things just patched it is an "Out the Shop Warranty"; otherwords, once it leaves the shop the warranty expires.
AVB out here that is classed as a "concrete warranty", once it leaves my concrete it is out of warranty
Posts: 349 Likes: 4
Hi,
I have been using a Chonda with the simple Red Victa boot and a self tapper screwed into the Chonda wire for many years. Goes very well, nobody has complained about TV interference or anything like that. This is a engine swap on a Rover Regal 19 frame. Had to put the Chonda on sideways and found that the rigid plug boot broke very easily against brick walls etc.No problem with the rubber boot at all.
All the best Jeff.
Posts: 1,842 Likes: 14
AVB, the Victa 2 strokes use the most primitive setup you could ever imagine, a small self tapper screwed into the end of the lead and a rubber boot slipped over it, but they work and that is all that matters Interestingly enough Norm, Victa only brought in that setup on the last of their full crank engines, and then carried it over to the PowerTorques. Previous to that, a crimped brass lug was used at the HT lead end. I'd say that what made it possible was going to a silicone rubber plug boot, which don't perish. Wouldn't have worked for all that long, with the older perishable butyl rubber type boot.
Cheers, Gadge
Hey guys, thanks for all the info  Here's a couple pics of what I'm dealing with... ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/04/full-9045-33831-honda_boot_1.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/04/full-9045-33832-honda_boot_2.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/04/full-9045-33833-honda_boot_3.jpg) As you can see, the Honda boot it broken and pulled from the cable. The VICTA boot, much different in design. I was planning on cutting the Honda cable and trying to solder the Victa onto it.. though the thickness of the VICTA wiring, not sure if it'll suck up all the heat from the soldering iron... ideas ?
You could something this but crimping could be a problem without right tools. For professional crimp it uses an open barrel crimper. These should be at the auot parts supplier and do make these adjustable (bendable)versions too. ![[Linked Image from chalmersindustries.com]](https://www.chalmersindustries.com/v/vspfiles/photos/Rotary-9161-2.jpg)
Posts: 349 Likes: 4
Hi,
I think I just used a self tapper and put the Victa boot straight over it. Not sure now, is that the way the plug wire is stock in your photo? If it is I probably did not need a self tapper, just put the Victa boot straight on. Has worked very well for a few years now.
Al the best Jeff
I can send you a Chonda cap for the price of the postage and you can just shorten the lead a little and screw it on. Let me know if you want it, it is never going to get used here.
You could something this but crimping could be a problem without right tools. For professional crimp it uses an open barrel crimper. These should be at the auot parts supplier and do make these adjustable (bendable)versions too. ![[Linked Image from chalmersindustries.com]](https://www.chalmersindustries.com/v/vspfiles/photos/Rotary-9161-2.jpg) Thanks AVB :), I'll check it out, though I think the insert hole in the boot might be too small.. it's about 2-3mm opening.. ill check it out anyways  Hi,
Al the best Jeff I'm not following  .. you used a self tapping screw? slipped the boot over the spark plug and self tapped to make contact ? As far as i'm aware, yup I believe it's the stock wire.. though I think this boot/wire came from a VICTA VC160 mower. I can send you a Chonda cap for the price of the postage and you can just shorten the lead a little and screw it on. Let me know if you want it, it is never going to get used here. Thanks Aussietrev  . Any idea on postage cost though? If it's possible to send as a large letter (Up to 260 x 360 x 20mm Up to 125g), Ill take it  .. think its about $2 Regards,
I'll find out after the break and let you know. It's ridiculous that Auspost now want $2 to send a birthday card that in February was only a dollar. I doubt that it will be under 20mm though so I'll check the small parcel rate as well.
Topics12,727
Posts106,665
Members17,965
