1 members (bigted), 10,673 guests, and 1,749 robots.
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
Sanli height adjustment knob
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
by NormK - 14/05/26 06:47 PM
by NormK - 14/05/26 08:27 AM
by NormK - 09/05/26 08:01 PM
by Bumps - 09/05/26 01:34 PM
by NormK - 07/05/26 10:15 AM
Image Upload Issue
#39046 14/08/12 09:35 PM
I have checked the valve clearances on my 28D707 '94 model and found the exh valve to have a clearance of 006" cold with the piston at 6mm past TDC.
I was going to take the time to correct this but I'll be damned if I can get the valve out. I can compress the spring yet the retainer on the end will not budge. Am I correct in assuming this lifts, toward the valve head to reveal valve cotters?
The exhaust valve looks newish and is stamped XTC yet the inlet valve has no markings. Correct to assume it's a replacement?
aldot #39051 15/08/12 07:53 AM
I haven't looked at that model Briggs, but most of them have a keyhole valve retainer: you just compress the spring by pushing down on the retainer (usually with your fingers) while holding the valve head to keep it from opening, then push the retainer sideways. After it moves sideways if you take the pressure off the retainer, it will just slip over the groove in the end of the valve stem and come off.
If your engine has car-style split collets retaining the valves, you will need to compress the valve spring with a spring compressor or (Joe Carroll's trick) a couple of cable ties, then push the valve head back into the closed position to free the collet from the retainer. Then you poke the sharp tip of a knife between the two halves of the collet, so they fall off the valve stem.
I've never had much success identifying whether parts are original or not. Factory purchasing departments keep changing their component sources depending on price, quality and reliability of supply. What they were buying six months ago is often no indicator of what they are buying now.
aldot #39053 15/08/12 08:34 AM
Thanks Grumpy. The description in your first paragraph is the inlet valve setup. I might nip down and grab a picture of the setup and see how we go.
aldot #39055 15/08/12 12:14 PM
Grumpy, on some of the bigger briggs engines they have a more automotive type of valve retainment with two collets.
Somewhat more of a devil to remove, but you can get the job done with scfrewdrivers, but in this case a small valve compressor does work the best.
17,960 Registered Users
Topics12,727
Posts106,660
Members17,960
(Release build 20251126)
PHP: 8.3.30 Page Time: 0.210s Queries: 23 (0.205s) Memory: 0.6280 MB (Peak: 0.6566 MB) Data Comp: Zlib Server Time: 2026-05-17 18:05:46 UTC
