1 members (Midas), 5,727 guests, and 1,583 robots.
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
Sanli height adjustment knob
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
by NormK - 14/05/26 06:47 PM
by NormK - 14/05/26 08:27 AM
by NormK - 09/05/26 08:01 PM
by Bumps - 09/05/26 01:34 PM
by NormK - 07/05/26 10:15 AM
Image Upload Issue
Hi,
I have a Homelite Super XL Automatic 2 stroke chainsaw.
UT10045B
I need to know following things
How to adjust the carby Hi - LO settings
Also May require new carby Kit its a Zama
Symptom is when I rev it it struggles to turn the chain.
Chain is not tight, removed chain bar and once revs pick up the clutch engages and i cannot stop it.
When i put the bar back on with the chain it struggles.
I have problems getting it to rev high, made some adjustments and cant quite get there.
Either clutch is seizing / binding and carby bogging down and going rich or just needs a tune or carby kit.
If anyone has a manual would be fantastic
Thanks Guys
dristo72,
1. Have you replaced the fuel filter in the tank?
2. Have you checked the sprocket to see if it has a groove in it?
3. Did you put the chain on correctly?
4. Is the chain brake damaged?
The first two questions are what is most probably causing the problems that you have. cheers2
Hi Bruce,
I will check the filter tonight, but wouldnt a clogged filter run it lean instead of rich?
Dont think the saw has a chain brake does anyone know where itwill be? Usually the hand guard is the brake but its just bolted on to protect the hands and it swings but doesnt lock the bar.
Chain is on correctly but has a slight grove in the sprocket teeth, maybe its slipping on that but doesnt make a noise that its slipping.
Can you let me knwo how to tune the hi and lo part of the carby?
thanks
dont forget im here if you need me
Calvin
Hi Calvin,
Checked and clutch is all good, filters are all good.
Great compression, helthy spark, new spark plug, exhaist port and mullfer clean and clear.
I can get the motor to start and rev but whne i load the clutch the engine bogs out. What i found when the manual choke is slightly open the chain woked really well and engine worked normally. if i open or adjusted manual choke either way the engine died especially when loaded. No matter what i do to the high and lo settings it wont work. I suspect dirt in the carby and or gaskets. Now i cannot find a way to remove the whole carby assembly, only the top half. Does anyone have any manuals or tips to remove the carby?
thanks
Hi, I managed to find out what the problem is.
The reed valve seat holds 4 read valves, one of them has snapped and obviously is drawing irregular fuel quantity.
Does anyone have a reed? the homelite part number is 59678B
The read seat that holds the reeds has the option of replacing the reeds. that part# is 63253
Does Bynorm stock these?
Hi Calvin,
I see in your post of obselete parts that you do have the reed valves. Whats your price on the part and postage to Brisbane Australia, Thanks
dristo72,
Below is the carby chamber which will show how to remove the carby.
UT10045B Carby Chamber.JPG (0 Bytes, 8184 downloads)
Carby Chamber Homelite Super XL Automatic Saw.
Hi Bruce,
Much appreciated, all doen got it ooff just need the reed to replace.
Do you have any in stock? part# as above
dristo72,
Sorry but at this time I am unable to help with the reed valve but if you contact a Ryobi dealer he might be able to help. cheers2
Hi Bruce,
Ill wait for Calvin, he has stock if not a guy on ebay has them
thanks Bruce
Sorry for my dislexic typos in my messages.
Fingers too big ha ha
Chainsaw Addict
dristo72,
You can get one from this eBay shop, I've bought from him before without any problems.
http://cgi.ebay.com.au/reed-valve-5...QQcmdZViewItemQQ_trksidZp1713.m153.l1262
cheers gmax
Hi,
thanks for that just bought one from him
Thanks guys for your help
sorry about a delay but yes i have them
Calvin
actually i have 8 left i would of not got them from randys on ebay charges too much for them my price on them is $ 2.75 each plus 2.95 in shipping first class mail which can take up to 2 weeks to get them i also ship usps priority mail international which is $ 11.95 flat rate envelope so if you would of waited you could of saved some funds i way cheaper than randy is
http://www.cmsmallengines.net/reed-1-2.html
Calvin
Hi,
Thanks for the heads up, i received the reed, yes it was expensive for a reed but I wasnt sure since its xmas time if there going to be any delays.
Do you stock Zama carby kits?
mine is a C2-20-02, A
part number A94953
94952 + 94954 is the upper and lower gaskets
also a new fuel screen too please
i can get the regualr zama kits if you want send me a email cmsmallengines at lycos dot com
Calvin
Moderated by  Bruce, Mr Davis
17,960 Registered Users
Topics12,727
Posts106,660
Members17,960
(Release build 20251126)
PHP: 8.3.30 Page Time: 0.098s Queries: 50 (0.082s) Memory: 0.7081 MB (Peak: 0.8117 MB) Data Comp: Zlib Server Time: 2026-05-16 22:24:05 UTC
