0 members (), 12,090 guests, and 1,618 robots.
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
Sanli height adjustment knob
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
by NormK - 14/05/26 06:47 PM
by NormK - 14/05/26 08:27 AM
by NormK - 09/05/26 08:01 PM
by Bumps - 09/05/26 01:34 PM
by NormK - 07/05/26 10:15 AM
Image Upload Issue
#62963 26/03/15 04:51 AM
Hi
Have just aquired a SB 45 with a Kirby HK30 motor, can anyone tell me the grade of engine oil and make to use.
Also engine won't idle? Serging on low revs.
Have just looked at your forum looks great.
Hello Beerman!
Welcome to these forums. I hope your experience is positive.
A straight SAE30 oil is fine, and recommended.
Expert moderators and/or members should be able to help you with
the surging problem on your Kirby.
Any photos are welcome.
JACK.
If your engine is hunting (repeatedly increasing then decreasing in speed, with a cycle-time of about 5 seconds), the usual cause is lean mixture. That engine had a main jet mixture adjustment screw sticking out of the side of the carburetor. It is easily identified: it has a spring under the screw head to keep it from moving unintentionally. There is another screw nearby with a spring under its head, which adjusts the idle speed.
To deal with the hunting, I suggest you start the engine, get it hunting, then slowly turn the mixture screw anticlockwise a little. Most likely no more than one eighth of a turn will cure your problem, which is usually due to some grime building up in the jet.
Hi Jack
Thanks for that info. have photos will workout how to send them.
Dave
17,960 Registered Users
Topics12,727
Posts106,660
Members17,960
(Release build 20251126)
PHP: 8.3.30 Page Time: 0.655s Queries: 23 (0.650s) Memory: 0.6328 MB (Peak: 0.6570 MB) Data Comp: Zlib Server Time: 2026-05-17 21:51:56 UTC
