3 members (Short94, Neggy, syd666), 2,104 guests, and 219 robots.
Re rotomo crankshaft.
Rotomo crank shaft
Oregon corded chain saw
by NormK - 05/10/25 11:12 AM
Out there cutting again.
19 Inch Razor Mulch Plug
by AMP - 03/10/25 01:01 PM
by NormK - 17/10/25 08:56 PM
Rotomo crank shaft
by maxwestern - 05/10/25 09:52 PM
Is it possible to still buy the cam that sits over the crankshaft and if not is there a way you can fastened the cam so it has no movement at all?
Ignore that last paragraph as I was not rite in the head . Ya have them moments.
Giday ,I cannot find a coil in store for this mower does anyone know where I might pick one up or a link as the one I'm after has two terminals and canno. Find on outdoor king store.
a coil like this one will work though you will have to re route your tension cable underneath. as it protrudes from a different angle.
http://www.ebay.com.au/itm/VINTAGE-...mowerAccessories&hash=item35c8d1a9db
Thanks gizmo,you where right about the coil being good . I put a new key in the keyway this fixed the tiny bit of slop the flywheel which ment a more stronger and even blue spark so that ment the coil was good. I also tested with a multimeter and was good reading also. I then cleaned the carby and tested the float and needle worked ,put it all back together and it runs really good. Miracles do happen . Great little mowerThankyou heaps for all the knowhow.
Hi,it sure is a great little mower. wink
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Dingo1985, RyanONeil, donk65, LewyQ, AAH
17,634 Registered Users
Topics13,008
Posts106,960
Members17,634
PHP: 8.3.25 Page Time: 0.028s Queries: 27 (0.021s) Memory: 0.6473 MB (Peak: 0.6835 MB) Data Comp: Zlib Server Time: 2025-10-19 07:33:59 UTC
