1 members (schwaggins), 2,798 guests, and 366 robots.
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
Early Morrison rotary mower
by schwaggins - 14/03/26 05:33 PM
Victa Super 24/600
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
by NormK - 22/02/26 02:31 PM
#4942 19/04/06 07:37 PM
Hi,
I have an 80A that is not generating any spark..Any info that anyone could provide or things to test would be much appreciated..
Thanks..
#4943 19/04/06 09:39 PM
Hi wwwspw,
I want you to try to do a couple of things:
1. First get a new spark plug.
2. Make sure that non of the wires from the coil are not earthing out.
3. Do that the wires from the stop switch are also not earthing out.
4. Disconnect wires earthing to the frame.
5. Check air gap between the coil and flywheel it should only be at the biggest a business card clearence.
6. Now test for spark by holding the plug against the frame.
The spark on these units is very poor at the best of times, so look very carefull. smile
#4944 27/04/06 11:53 PM
Hi Bruce,
Thanks for the above, I checked that and all appears to be ok. I had the coil tested at a repair centre and was told it was dead. Is it possible to fix it or is there available a replacement coil?
Thanks and Regards.
#4945 28/04/06 12:35 AM
wwwspw,
The part number that you require is 217439 coil. I will let you know in the next couple of days if I can get new or second hand. smile
#4946 28/04/06 12:42 PM
Great, thanks alot..
#4947 28/04/06 01:02 PM
wwwspw,
Can you post a picture of the coil on the board as I have located a couple of coils but just want to confirm.
Go to this link so that you can post a picture on the board. woot
Help topic Outdoorking Bulletin Board
#4948 28/04/06 07:04 PM
Bruce,
It's a SEM AM32, but here's the pic..
http://i54.photobucket.com/albums/g114/wwwspw/28-04-06_1737.jpg
Thanks and Regards.
#4949 28/04/06 10:36 PM
wwwspw,
That coil looks the same as a roybi coil are you sure that it is the original coil? confused
#4950 30/04/06 05:43 PM
Hi Bruce,
Yeah, it's the original coil..
Thanks and Regards.
#4951 30/04/06 08:25 PM
wwwspw,
Ok I will see if I can locate a good second hand one. :Wavey:
#4952 30/04/06 08:27 PM
wwwspw,
Can you give me a picture of the other side of the coil as well please. smile
#4953 01/05/06 01:43 PM
Hi Bruce,
Here you go, http://i54.photobucket.com/albums/g114/wwwspw/01-05-06_1240.jpg
Thanks and Regards.
JTB, maolizi, MamaBear, AliPike, Evomk2pete
17,876 Registered Users
Topics13,071
Posts107,310
Members17,877
PHP: 8.3.30 Page Time: 0.034s Queries: 38 (0.028s) Memory: 0.6734 MB (Peak: 0.7341 MB) Data Comp: Zlib Server Time: 2026-03-14 06:51:19 UTC
