1 members (KevinJP), 1,443 guests, and 479 robots.
by Damon - 07/01/26 07:01 PM
Briggs CD's
by Bruce - 07/01/26 08:34 AM
Deutscher 360
by NormK - 03/01/26 12:39 PM
3-stud rear wheels and axle flanges
by wilbur - 03/01/26 11:15 AM
Suzuki Rover 2-stroke (M122X)
by AdamTwoStroke - 01/01/26 11:33 AM
Scott Bonnar ID
by Leifc145 - 29/12/25 08:09 PM
by maxwestern - 08/01/26 12:38 AM
Briggs CD's
by maxwestern - 04/01/26 09:06 PM
by wilbur - 04/01/26 10:52 AM
Deutscher 360
Austral Villiers Engines
by Lumberjack91 - 01/01/26 10:43 PM
by maxwestern - 30/12/25 04:49 PM
Scott Bonnar ID
kew
Offline
Hi,
I have had this Honda Lawn Mower since new (HRU194). It's running fine like it always has, starts first go, idles nicely, no smoke etc.
I do find that at times I would like it to rev higher. I am aware that it has a governor fitted but I feel that it is not revving high enough. What do I need to adjust to make this happen?
Nathan
You can begin by making sure your governor is working correctly. The process for setting up the governor is as follows:
1. Loosen the governor arm pinch-bolt, and move the governor arm to fully open the throttle valve.
2. With the governor arm held in the fully open position, turn the governor arm shaft in the same direction as far as it will go using a small wrench across the flat on the shaft, and tighten the pinch-bolt.
3. Check to be sure the governor arm and throttle valve move freely.
kew
Offline
Thanks for the reply. Every year I do the maintenance as per the handbook which includes the governor adjustment, tappet adjustment etc.
In the past, I have adjusted the governor by holding it in the fully open position just with my fingers but this time I used a pair of pliers which has provided a much better result. The RPMs have increased!. Thanks.
Glad it's sorted out, kew. That governor setting process seems to need more hands than one person has, which I think is why Honda describes it in so much detail. I'll close this thread. If any member wants to post to it again, just PM a moderator.
Kdizzle, Anteater3195, MadVintage, Ripgently, Tilo15
17,783 Registered Users
Topics13,050
Posts107,192
Members17,783
PHP: 8.3.28 Page Time: 0.049s Queries: 22 (0.044s) Memory: 0.6363 MB (Peak: 0.6562 MB) Data Comp: Zlib Server Time: 2026-01-08 12:24:04 UTC
