0 members (), 875 guests, and 652 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Lectron Generator Fuel Pump
I was dismantling this motor and found this cavity at the top of the engine under the magnetic flywheel. It is covered by a plate and gasket held on with two small bolts (removed). It has this steel mesh tucked in a cavity (visible in the photo).
Any idea what this is for? Very curious.
PCV valve MF. idea is to let air but not oil out - doesnt always work that way on the cheap ohv motors haha
Thanks for the fast response Tyler.
Do Hondas have this?
yep, definitely do. Also sport a better quality beige one way flap thats less prone to gumming up
MF all 4 stroke engines have the crank vent system, without it they would blow gaskets everywhere when the piston is on the downstroke the pressure has to go somewhere. On a 2 stroke this downstroke piston pressure is what pushes the fuel/air in the crankcase up above the piston through the transfer ports
Hi NormK and Tyler,
not such a surprise then, bog standard.
First time I've pulled off the upper flywheel from an OHV engine.
17,714 Registered Users
Topics13,031
Posts107,112
Members17,715
PHP: 8.3.27 Page Time: 0.038s Queries: 28 (0.033s) Memory: 0.6401 MB (Peak: 0.6924 MB) Data Comp: Zlib Server Time: 2025-12-11 04:27:13 UTC
