1 members (Peter9231), 2,509 guests, and 244 robots.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
Early Morrison rotary mower
Shout Box
by Bruce - 16/03/26 08:10 AM
by geobee - 15/03/26 05:27 PM
Victa Super 24/600
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
Hi All,
I have the Rancher model 1755. I have the Parts manual and owners Manuals.
I have a new belt ( A07641 ) Belt clutch drive (42). My problem is neither manual shows me how the belt runs around the pully system.
I had to get a new belt as the old one exploded and I was not able to get a photo on how they ran before hand.
So if anyone has a few photos they could post that would be great.
I live in North Brisbane, if anyone knowns a good mower shop for more help.
jamie
Hi Jamie
I don't have a Rancher 1755 but these images might help.
The link below some of the images are wrong where the v belt is but the text explains.
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=44873
Max that first diagram is a rancher 2 not a 1755, 1755 is transaxle drive. really simple as there is only 1 idler. you can see it pretty clearly in this diagram
so 17 is the engine pulley, and it goes straight to #5 and then around #8 the tension idler pulley. it is spring loaded and on a linkage to the brake pedal.
You will need to take the smaller deck belt #24 off at the front to get the clutch belt on the top of the engine pulley
The whole process is easier if you remove the keepers #16 and #20
Nath, Thank you so much !!!
My problem was I had belt (42) on the wrong side of pully (8)
RE keeper (16) im guessing my belt (42) should be on the inside of 16 and 20 ?
Also thank you Max.
Wow what a great team, your help has saved me.
I hope to fix it all tomorrow and get my lawn done, weeds a 5 foot tall !
Lastly, spring 32 (A07745) on the cutter deck is connected only at the spring end, where does the hook end connect ? im thinking on page 2 Chassis maybe on (20) or (23) Arm rear / Arm front ?
jamie
Yes, both belts need to be inside the keepers.
That spring, 32, There should be 2 of them, one on each side. one end hooks through the top of the deck housing (you should be able to see it beside the u bolt, the other should be attached to a bolt on the frame above the deck. #34 I believe. The idea is they pull the deck toward the rear of the mower to tension the deck belt.
Git it, Thank you.
8-)
jamie
Bowzie, Rowie_77, johnny rotten, SBColllector, JTB
17,880 Registered Users
Topics13,073
Posts107,317
Members17,880
PHP: 8.3.30 Page Time: 0.058s Queries: 32 (0.050s) Memory: 0.6491 MB (Peak: 0.7034 MB) Data Comp: Zlib Server Time: 2026-03-16 22:36:38 UTC
