0 members (), 3,062 guests, and 1,050 robots.
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
by vint_mow - 30/04/26 11:02 AM
by vint_mow - 30/04/26 10:50 AM
by looktall - 29/04/26 02:48 PM
by AVB - 28/04/26 09:59 PM
Rover Rancher 1766 Ignition Barrel wiring
by RayWill - 27/04/26 06:55 PM
by vint_mow - 27/04/26 06:02 PM
Rover height adjust plate
by vint_mow - 27/04/26 08:24 AM
by vint_mow - 27/04/26 08:23 AM
by Lenoleno77 - 27/04/26 07:55 AM
#9817 12/10/08 04:06 AM
Hi guys.
I'm "repairing (yet again) an old Victa 2 stroke (plastic carby type, orange base, black engine) I guess it's an 80s model of some sort.
My ex found it (abandoned) some time ago & I cleaned it up & got it running for her (saves me using my new B&S on her grass).
Anyway in the process of replacing the coil (purchased a new coil) but my problem is in re-assembly, I can't remember where the black & brown wires go.....I've completely forgotten from where they came, I know they relate to the engine cut out some how but I'm really stuck.
Any assistance would be greatly appreciated, even a pic.
Thanks in advance.
Dok,
Here is your drawing:
coil system
Thanks Bruce, much appreciated.
Also, is it possible to replace the piston in this model (Vantage I believe) after all the work I've done on it I still can't get it to fire (spark is good, fuel is getting through to plug) but it feels low on compression, + looking at the piston (through the exhaust port) it appears terribly scored, upon speaking to my ex, she informs me when it stopped working there was smoke coming out the top of the casing (directly above the barrel) so my synopsis is she's not got the fuel mix right & cooked it??
It appears as though the barrel is part of the engine assembly hence making access to the piston impossible.
Should I persevere or call it quits on this machine???
The Dok,
You will need to rebore the cylinder and replace the piston. cheers2
Have a look around for a used block at your local mower shop, I cant even give good blocks away half the time.
Thanks for the tips guys.
I'll mull it over & keep you posted. smirk
Hi Dok, It's great to see that you are persevering with it,you will have a lot of self satifaction when it is running perfectly again.....Best wishes for your project mate, don't forget to post pics when it's finished!! wink
Jones666racing, EasyMoney, Port Fairy Lawns and, RayWill, Matty_H95
17,939 Registered Users
Topics13,089
Posts107,393
Members17,940
PHP: 8.3.30 Page Time: 0.042s Queries: 32 (0.036s) Memory: 0.6484 MB (Peak: 0.7104 MB) Data Comp: Zlib Server Time: 2026-04-30 19:19:41 UTC
