1 members (aayliffe), 4,060 guests, and 589 robots.
by niggz - 09/09/25 10:09 AM
McCulloch Mowcart 66
SEVEN Victa Utilities
by NormK - 14/09/25 12:16 PM
by Bruce - 12/09/25 05:08 PM
by Bruce - 12/09/25 12:01 PM
by Bruce - 06/09/25 06:33 PM
More Cox Cone Help
#90283 28/02/18 08:25 PM
I need to build up a 30mm shaft that is worn by .2mm. I'm thinking of using JB Weld on it and then turn it down to suit the bearing. Has anybody done this, my other alternative is to run a thin bead of weld around it but I'm not happy doing that because it may have a detrimental effect on the composition of shaft. Any thoughts and I don't think I could speedie sleve it
NormK #90286 01/03/18 01:45 AM
Personally I never had any good with JB weld on anything other than no stress items. I see way this going to work since it a lot weaker than the metal that has already been worn. I even tried a product by Prematex call Steel Weld epoxy with terrible threading results. It would have never held mounting blade spindle.
If you can't get a replacement shaft then welding would the best option in my opinion; just make sure to center the journal on the shaft for balance.
Question though as why journal is worn so far in the place. Was it one those journals the roller bearing fitted on loosely? If so then the new shaft would do it again; unless, the journal is knurled so bearing has slight press fit. If is instead a bushing type bearing then the journal area need to near perfect smooth to prevent wear.
NormK #90287 01/03/18 08:54 AM
Thanks AVB what I thought, didn't think it would work but always pays to ask. I think I will go with the weld but I might just put a small spot of weld in 6 spots, this saves the ring effect of a weld all the way around, then I can turn it back to suit the bearing.It is just a roller bearing so it should be fine.
NormK #90298 02/03/18 10:45 AM
Senior Contributor
I tried JB Weld to build up a shaft one time. It was a failure. It is great stuff for repairing fins and patching holes etc., but not much good where any kind of stresses or movement occurs. The only other solution might be to sleeve it.
NormK #90308 03/03/18 09:22 AM
There was a product called speedy sleeve, we used them on worn shafts. Came in a lot of sizes, may still be out there
It is
http://www.skf.com/au/products/seal...ear-sleeves/skf-speedi-sleeve/index.html
NormK #90311 03/03/18 11:29 AM
Still working on it I have to make up a mount so that I can mount my grinder to the lathe to finish it off but it all takes time and lots of other things keep getting in the way. Hopefully I will get back to it before I get too much older
Moderated by  Bruce, Deejay
TommyT, BJSwart, Scruffy Pix, Apollo11, blindsided
17,583 Registered Users
Topics12,992
Posts106,840
Members17,583
Most Online14,275
Sep 11th, 2025
PHP: 8.3.24 Page Time: 0.038s Queries: 27 (0.031s) Memory: 0.6409 MB (Peak: 0.6780 MB) Data Comp: Zlib Server Time: 2025-09-15 06:47:38 UTC
