2 members (Brad1087, 1 invisible), 430 guests, and 893 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Lectron Generator Fuel Pump
Hi I replaced a new rear carrier on my Victa 550 SP and the strange things happened...
For the normal working condition SP Victa 550, when SP cable is engaged, this stops rear wheels going backwards.
What my mower does now, is when I engage SP cable, it stops rear wheels going forward....
I am thinking is there anything I have done wrong during the process of replacing the rear carrier?
Hello detective007
I don't know this machine at all, but ...
Is it possible you have the pawl pinions reversed.
There is a left hand and right hand side (?).
Can any member help here?
Hi Jack,
Thanks for your input.
What is pawl pinions?
Hello detective 007
When you said you replaced the 'rear carrier' what did you mean?
Did you remove the rear wheels at all?
Hi Jack,
Rear carrier is what rear wheels connect to. Yes I stripped everything apart including both rear wheels
seanw
i dont know if i can help but if you post a few pics maybe vvcomm will pipe in.
Sean
motorwannabe
Ok. I will post up some pictures tomorrow.
Thanks and Good night.
it sounds like as Jack said , you have reversed the clutches they are left and right , the cog looking parts inside rear wheels it IS easily done as they look almost the same , try just swapping side to side complete . means clutch , key ,washer and all related parts .. meaning all the parts you see when you remove the wheels try to keep them matched up if you did already .
its the only thing i can think of right now as its an easy mistake to make .
hope it works out for you cheers2 , Dave
Thanks vccomm
You explained that better than I did.
I found an illustration. There is a left-hand and right-hand spring
in the drive carriers. Simply swap the drive carrier assemblies side-to-side.
This is the most obvious explanation for what you have described.
Hi here are two picture on the SP part.
Hi Thanks for your explanation. I will switch over all relative parts when I have time tonight, will come up here to update later.
Hi I swapped cogs side to side and the SP function works as it should. Yes these two cogs are almost the same by just the looking of them, but they are small difference between them if look very closely, which affects the SP function.
Thanks for your help.
smile well done there 007, Q wasnt needed . good you worked it out
good1
Hi Sorry to bother you again. Does the 550 SP gearbox need to be greased?
only if you had it apart , or if your just wanting to check or clean out ? then yup , last one i just used a good moly' type same as i greased my car with , the really messy black stuff seems to stay softer longer doesnt dry up .
ps , energrease AO or equivalent so the bible tells me , i just looked lol... so if you like to go by the book there ya go wink
markalan28, Taras, Tool, Blakewell26, Aaron.
17,720 Registered Users
Topics13,031
Posts107,113
Members17,721
PHP: 8.3.27 Page Time: 0.085s Queries: 47 (0.074s) Memory: 0.6929 MB (Peak: 0.7733 MB) Data Comp: Zlib Server Time: 2025-12-13 22:24:02 UTC
