Hi Forum,
I've recently aquired an old Deutscher R360 ride on lawn mower which is in reasonable condition, but the wiring harness is a mess.
I believe it was fairly simple. It has an on/off keyed ignition, and a push button starter button.
The motor is a Briggs and Stratton 14.5hp, Intek
Model: 287707, Type: 1274-E1 Code: 000825ZD
I assume that:
- a thick starter cable has to be run from the positive terminal on the battery, through the push button starter switch to the starter motor,
- a thick earth cable has to be run from the negative battery terminal to the engine block
- there are two cables from the motor itself. I assume that one will need to be connected to the positive terminal on the battery via the start switch, so the engine charges the battery. Where does the other wire need to be connected to? Does it lead to the engine kill circuit?
- there is no kill switch fitted to the seat
- I am yet to determine if a anti-afterfire solenoid exists
Can anyone provide a wiring diagram that suits this engine, and an R360 Deutscher ride on lawn mower with this fairly simple starter set up?
Thanks in advance
