2 members (TonyD, DeanVR4), 4,980 guests, and 1,289 robots.
#52741 18/01/14 06:08 AM
Gday , I have a sanli with oil running out the breather hose while the motor is running, everything looks normal,but I'm not sure if the little yellow valve is up the right way and if there's a part missing or not. [Linked Image]
The motor runs fine ,I just can't stop the oil . There is a gap under the valve and i can see right through and I can see part of the bottom oilseal and bearing . Is this for oil or heat to pass through and there is another little drain hole which I have unblocked. But before I put it back together ' I'd like to make sure. Thankyou.
roebuck #52761 18/01/14 07:30 PM
Hi Rob. First, had you taken the oil separator (circled in green) out and put it where it is? It has to go in the PCV compartment, at the tip of the green arrow. Its purpose is to strain out the oil from the ventilation gas, and return it to the crankcase through the tiny return hole.
Second, the pale yellow disk (circled in red) is of a different and I think inferior design to the Honda one. Honda uses a hard flat brown plastic disk, which looks fibre-reinforced. After a very long time, the Honda one wears somewhat in the center, where it hits the stop circled in yellow in the above picture. To see whether your disk is in the right way up, look at its center to see which side has been in frequent rapid contact with the stop.
Here is the Honda disk:
I think I'd be inclined to fit a genuine Honda disk.
Have you read this thread?
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=49601&page=2
Way down at the end of it there is an explanation of the Honda PCV system.
roebuck #52765 18/01/14 09:16 PM
Thanks Grumpy, I remember that post well know . I have one wrecked honda so I hope that will do the job. I'll do that today and post results. Thankyou.
roebuck #52767 18/01/14 09:50 PM
Just be careful that the genuine Honda one is not too worn, Ron. Here is one I've been reluctant to use, but haven't been disgusted enough with to throw away:
Edit: Also, don't forget to push a drill bit down through the drain hole at the bottom of the oil separator compartment. If that 1.8mm hole is blocked, you'll get exactly what you've been getting.
roebuck #52782 19/01/14 06:54 AM
Grumpy, all went well with the honda valve' amazing how a little valve could do this. The hole was definatley unblocked before reassembly, so i had a good outcome and funny enough I've got another sanli to do so hope I havn't got the same problem because I don't have any more honda valves to spare. Are they hard to get new ?
Thankyou again Grumpy ,you got me out of another pickle once again. rockband smashpc
roebuck #52787 19/01/14 06:12 PM
It's all good Rob, it expands our case files in the archives. Also, I hadn't seen a chonda valve disk before, and now that I have, I'm not impressed.
When you swap a Honda hard fibre disk for a chonda plastic disk, I think it is best when possible to replace the tin cover (the "Breather Chamber Cap") as well, because the Honda one has a somewhat flat stop instead of the relatively pointed one used by the chonda:
The disc valve is called "Valve, Breather". The Honda Part Number is 04521511, but more importantly the "HP#" is 12372-879-000. It seems to be used in a huge variety of Honda engines. US List Price is only $1.87, but shipping to Australia is a problem as usual. There may be a way to get a decent-quality non genuine one, instead of that soft-looking plastic thing, but I didn't find one with a couple of minutes searching. You're at least as good at finding them as I am, so I'd best leave it to you.
roebuck #52790 19/01/14 07:41 PM
I'll have a good search tonight, Grumpy in another thread you mentioned a part called the oil defencer I think, that tube when correctly installed ,is it ment to point in the direction the engine rotates ie bore or the other way or as it appears can it only go in one way [Linked Image]
roebuck #52791 19/01/14 08:10 PM
"Pipe, oil defense, P/N 1825702 HP# 12385-ZE6-000". Thanks for posting that picture, Rob. The crankshaft and camshaft obviously rotate in opposite directions in engines that have timing gears, and viewed from that end (the PTO end) the crankshaft rotates anticlockwise and the camshaft clockwise. However the defense pipe projects into the crankcase cover, not far from the oil slinger, which will have much more important effects on the amount of oil thrown at it. Incidentally I do not see that pipe as a masterstroke of Honda engineering - it looks like something they invented during the engine development process, after they found they had a problem.
Note that I don't know which chondas have plastic timing gears like yours. Honda has cast iron timing gears and camshafts in the GXV120 and GXV160 - of the GXV engines, they only have the plastic gear and cams in the GXV140. Of course the GCV engines have a plastic moulding that is timing sprocket and cam lobe all in one flat piece. It pivots on a loose steel shaft that slides through the center of it, so the timing gear/cam can be retimed, or completely replaced, in the blink of an eye. Just as well, too, since it is a bit prone to losing its timing.
roebuck #52793 19/01/14 08:45 PM
If you would like anymore particular photos of this chonda I'm pulling the rest of it apart today .
Crankshaft Top seal is nhk tc 22. 35. 7. 33 , bottom seal nhk tc 25. 38. 7. 26.etc
roebuck #52797 19/01/14 09:25 PM
I'd like to have a record of anything different from the Honda GXV160 that most of the chondas are copied from, Rob. I'm not sure there is much that is visibly different except the control linkages for the governor and choke - which you have already posted. As was reported in another thread, there are detail differences in some chonda flywheels and crankshafts which keep them from being interchangeable, but it is a whole study in itself to line the parts up beside Honda ones to show that. If you could show the ignition module mounting, we can see whether it follows the GXV120 design, or the one used on both GXV140 and GXV160. If you have the carburetor off, you could show the air cleaner housing, the carburetor insulator, and a general view of the carburetor.
Thanks for the offer.
Post edit: Note that this Sanli chonda is 140 cc displacement and is quite an accurate copy of the Honda GXV140. The plastic camshaft is the same as the GXV140 one and may be interchangeable with it. Note also that unlike Honda's design practice with the GXV120 versus the GX120, and the GXV160 versus the GX160, Honda designed the GXV140 separately from the GX140 and they do not even share the same stroke. Do not expect GX140 parts to fit a GXV140: some will, and some won't.
roebuck #52800 20/01/14 12:35 AM
The gxv160 coil fits perfectly. [Linked Image]
Let me know if you need more.thankyou.
roebuck #52802 20/01/14 02:17 AM
The photo of the coil is for a gxv160 and I'm not sure if it will work on a chonda yet but I will give this a quick try when I put back together and let you know . As you can see the honda coil sits on there nicely but if I turn it over it doesn't and I'm not sure if I've got it sitting up the right way in the picture.
roebuck #52803 20/01/14 02:47 AM
Thanks Rob. There is one point that may have been cleared up, and one that isn't clear yet.
Here is an ignition module from a GXV120:
Here is one from a GXV140:
Here is the mounting location on a GXV140, which is the same as your chonda:
I had thought that the GXV140 and GXV160 used the offset mounting points, which the GXV140 coil pictured above used. If my recollection is correct, the GXV120s I have only have the two mounting points for the symmetrical GXV120 coil. The GXV140 and GXV160 have the three mounting points so they could use either type of coil. I had been guessing that all GXV140 and GXV160 use the large coil with the offset mounting points, but you have shown a small coil with symmetrical mounting points, and you said it came off a GXV160. So, that is the first question: do GXV140 and GXV160 engines sometimes use the small ignition module?
The second question is, can I see the other side of the carburetor insulator please, and the intake port of the chonda? The reason I ask is that I'm not yet sure it is the same as a GXV160 insulator, which is a big thick object to transition from a round carburetor opening to a square port on the cylinder head, like this:
The GXV160 uses a giant inlet port, where the GXV120 and GXV160 both have the smaller ports, which do not require the giant insulator. Also, only the GXV160 has the vacuum port in the side of the insulator. The reason this matters, is that it may turn out 163 cc chondas have small inlet ports, which would reduce their power output below that if the GXV160.
roebuck #52807 20/01/14 05:42 AM
The first question I don't know, to the second question [Linked Image]
The last photo are two different insulaters ,both used on the same chondas and all the chondas so far are the same as per photo to my knowing. Sorry Grumpy but I'm bit confused. Tmrw I'll take the top of the gxv140 and take a photo of the coil and post.
roebuck #52812 20/01/14 07:25 AM
Grumpy I have put a gxv160 carb on a gxv120 and it works well . The insulater doesn't seem to make a difference as it has a beveled circle and some insulaters have a beveled circle with one square edge to match the intake and both of these are found on chondas ,as far as I know both insulaters do the same job as per very last photo but the one in your photo and I'm only guessing the one in my photo is a full circle and they maybe a match to do the same job. Not sure , thankyou.
roebuck #52822 20/01/14 06:42 PM
Rob, with regard to the two different ignition modules, I think I've found the answer in the GXV160 workshop manual:
It seems there were two different ignition units used on some GXV models: a conventional electronic unit (N type), and a capacitive discharge unit (A type). The small unit in my picture in the previous post was the N type and the large unit was the A type. I haven't yet seen an A type on a GXV120 - they may not have used them on that model. The alternative mounting points on some Honda cylinder blocks are for the A type, and may not be provided on GXV120 blocks, though they are on the GXV140 and GXV160 blocks.
The GXV160 intake ports remain unclear at the moment. The parts list shows the GXV140 having 16211-ZG9-000, which is the insulator shown second in your list, and the GXV160 having 16211-ZE7-000, which is the thicker insulator for a large square intake port.
The first insulator in your pictures is for the GXV120, which has a round intake port. The second is for the GXV140, which has a D shaped intake port. The GXV160 remains an unsolved mystery.
You probably know that the GXV120 and GXV140 have the same stroke and different bores. They share the same crankshaft, connecting rod, and many other parts. However they have different cylinder heads to suit the different bores.
The GXV160 (68 mm)has a larger bore than the GXV140 (64 mm) which itself has a larger bore than the GXV120 (60 mm). The GXV120 and GXV140 have the same stroke (42 mm) while the GXV160 has a longer (45 mm) stroke. It would be physically possible for them to share the same cylinder head.
So, thank you for that, your post has led to unravelling the matter of the two ignition modules. The matter of the intake ports and carburetor insulators remains mysterious.
roebuck #52824 20/01/14 07:18 PM
Thanks Grumpy , that was very interesting,I will take more notice of which insulater is for which in the future .
roebuck #53529 10/02/14 10:19 PM
Hi Grumpy , I just rebuilt a honda gxv 120 which had no carby ,fuel tank or throttle mechanism or control plate so I had a sanli powercut donar with a huayi carby. I put only one o-ring with new idle jet. After new piston rings etc all put back together minus cowl and pull start etc it worked perfectly. This was a fun little job till I get original parts.
The new idle jet was a very tight fit so I didn't think it would work in the huayi carby but it did perfectly, the original huayi idle jet looked a little different to the new one ( the metal jet insert )which you can't really see that good . The one on the left is original huayi idle jet. [Linked Image]
roebuck #53532 10/02/14 11:44 PM
Thanks Rob. I haven't encountered Huayi carburetors yet, only Keihin on real Hondas, and Ruixing on chondas. It seems Huayi is a Ruixing competitor.
Was the Huayi idle jet 0.38 mm, like the Keihin and Ruixing idle jets?
As you know, Keihin idle jets are all plastic, like the Huayi, while at least some Ruixings have the brass bush in the idle jet. In principle I like the brass bush better - it should be easier to clean without damaging it.
It will be interesting and useful to find out more about the details of various chondas. As I've said before, I think we'll all be using them before long.
roebuck #53533 11/02/14 12:17 AM
I can put a 0.3 drill in the new idle jet easily, put in the huayi could only just manage to push the drill in, with 0.35 drill I cannot get in either idle jet. The ruixing had the same result as the huayi but the keikhin I could fit a 0.35 drill. The next drill size I have is 0.4 and doesn't fit in any.
roebuck #53535 11/02/14 02:07 AM
Thanks for your patience Rob, as you know (but I had forgotten) I've already made that test myself with the the Ruixing one and the Keihin one, and got the same results as you did. So the Huayi idle jet is slightly smaller than the Ruixing, which in turn is a bit smaller than the Keihin. The Keihin is officially 0.38 mm, but for the others we don't have official figures and can only guess, since both of us only have jet drill bits in size intervals of 0.05 mm. With the idle jet it doesn't matter much because you can adjust the idle mixture screw to compensate. With the main jet you can't adjust anything to compensate, and the Ruixing one is approximately 0.60 mm in their GX120 version. In the Keihin, the main jet is 0.60 mm for the GXV120, and 0.55 mm for the GXV140. I haven't measured a GXV160 one. So, at this stage there is no great difference in the jetting for the GX120 versions of the Keihin (Honda) and Ruixing (chonda) carburetors. The Huayi, presumably another chonda, so far has a compatible idle jet, and we don't yet know about the main jet. So far, our starting-off guess that the chonda bits are mostly interchangeable with Honda bits, is standing up fairly well. However we do know there are bits that don't interchange - in particular, some flywheels. I'm pretty sure the ignition modules for chonda and Honda will usually interchange, at least on the GXV140 and GXV160, but I'm not so sure about the GXV120. I have a vague recollection that the GXV120 cylinder block does not have the dual set of ignition module mounting holes that the GXV140 and GXV160 have. Would you mind having a look on the genuine GXV120 you are working on, and see if it has the three module mounting holes, or only two? The two holes would fit an N type module, but you need the extra, offset hole to fit an A type module. I'd check it myself but I don't have a spare GXV120 block any more, having thrown out a couple of worn-out ones.
roebuck #53539 11/02/14 06:04 AM
Ok I'll do this tmrw and put up a photo.
roebuck #53563 12/02/14 01:09 AM
Grumpy, theres nothing wrong with your memory.The photos in order gxv120 without coil
Gxv140 without coil and without coil spacers ,and with coil spacers
Gxv140 with gxv140 and gxv160 coils and neither fit the gxv120 but the gxv120 fits the gxv140 and the 140 chonda and I don't know if that would work as you can see the rear right hole has not been tapped .
Chonda SL1P64F =(140) without a lot of stuff,
Chonda SL1P60P =(120) without coil which are (the coil) interchangeable with chonda (140) and visa versa, the chonda coil works perfectly on a honda gxv120.
roebuck #53564 12/02/14 01:26 AM
A honda gxv160 without coil
roebuck #53567 12/02/14 02:35 AM
Thorough as usual, Rob, and very clear pictures. So, if I'm interpreting correctly, the Type N module (standard on GXV120) will fit any Honda or chonda, but you have to tap the right hand hole to fit it to a GXV140. However the hole is already tapped on the GXV160. The Type A module (standard on GXV140 and GXV160) will fit any GXV140 or GXV160, but cannot be fitted to a GXV120. The chondas follow the same rules as the Hondas, for what will fit on each model.
Thanks for doing that - now the archives will show the differences and what to use where. The one question not answered yet, is whether the GXV120 module (i.e., the Type N) will work properly on a GXV140 or GXV160, and whether it would have to be fitted on the spacers, because of a difference in the flywheel?
There is probably a reason that Honda decided to fit only Capacitive Discharge Ignition (that is, Type A) modules to those larger engines, while continuing to fit the standard modules to the GXV120 (which was the first of the three models to be designed and produced). Conceivably the CDI module will work better than the standard one under some specific circumstances. Generally CDI works better than standard ignition if the spark plug is fouled, but works less well than standard ignition if the mixture is lean.
roebuck #53576 12/02/14 07:54 AM
Iwill try the standard gxv120 module on the 160 tmrw,the armeture is the same thickness so I will use the spacers. The armeture on the standard 140 module is a fair bit thinner and so is the replacement 160 module but they still match in with the flywheel magnets and from what I can tell you would use the spacers on either 140/160 flywheel.
roebuck #53583 12/02/14 05:41 PM
While you are doing that Rob, you might be able to clear up some flywheel-related questions.
1. There must be a reason for the GXV140 and GXV160 requiring spacers under the ignition module, where the GXV120 doesn't. Are the rims of the GXV140 & GXV160 flywheels deeper than the GXV120 flywheel? That might explain some problems a member had in another thread, with flywheels.
2. The GXV120 has a cast iron flywheel, where the GXV140 has an aluminium one. Is the GXV160 flywheel cast iron, or aluminium? If aluminium, is it the same as the GXV140 one? Are the magnets the same on all the flywheels - same number, in the same place?
3. Are the chonda flywheels the same as the Honda ones, for all three models? I'm not suggesting you pull the flywheels from these engines to find out, but hopefully you will be able to tell without doing that.
roebuck #53589 12/02/14 08:52 PM
Ok the gxv120 module works perfectly on the gxv160 with the spacers. I will at the flywheel shortly and measure .[Linked Image]
roebuck #53590 12/02/14 09:49 PM
Chonda 120 flywheel diameter 170mm and 40 mm thick
Chonda140 :-) :-) as above
Honda. 120. :-) :-) 160mm. 40mm
Honda. 140. :-) :-) 170mm. 35mm
Honda. 160. :-) :-) 170mm. 40mm
All these measurements are approx. All measurements where taken from the magnets and not including the fins. The honda gxv140 measures 35mm where the magnets are and then reduces down to 30mm.
The first three on the list are cast iron gxv140,gxv160 alloy. [Linked Image]
roebuck #53593 13/02/14 01:24 AM
Thanks Rob. Those measurements don't seem to tell me why the GXV140 and GXV160 use spacers under the ignition module while the GXV120 does not. That is a mystery still to be solved. It also sounds as if a GXV140 or GXV160 aluminium flywheel might fit on a GXV120, in place of the cast iron one. I doubt it would kick back, because the GXV140 doesn't kick back. However the GXV120 has a plastic fan that sits on top of the cast iron flywheel, while the other two have an integral aluminium cooling fan, so there may be issues with the starter cup. Not something I'm going to try in the short term, because I don't have an aluminium Honda flywheel anyway.
18,159 Registered Users
Topics12,760
Posts106,815
Members18,160
