Aldo, Honda specifies a maximum governed speed for that engine of 3200 rpm:
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2013/04/full-2772-10418-honda_gxv160_governed_speed.png)
There are two factors likely to be involved in that. One is the US mower safety standards, which effectively limit the maximum blade-tip speed, so that rocks won't be thrown excessively hard. The other factor is engine durability. Engines last longer at mid-range speeds than at either very high or very low speeds.
So, my comment on the video is that the guy has missed the point to some extent. I always recommend following the manufacturer's recommendations, and that is 3,200 rpm maximum speed.
With regard to the sudden speed increase rather than it happening smoothly, I suggest you look closely at the set-up of the throttle cable and the speed control linkage. In the picture you posted, there seemed to be excessive slack in your governor spring when the cable was in the stop position, and the kill switch was being heavily mashed by the link that operates it. If you adjust the cable so that the kill switch is just operated relatively lightly at the extreme rearward movement of the speed control, the dead band of the speed control should be reduced.
