10,553
631
I need an illustrated parts catalog. I bought this unit new a few years ago and never used it. I took it out last weekend and it worked fine. However, this morning the rubber fuel primer bulb was cracked and the saw would not start. How complicated is the replacement of this bulb and where is a good place to get the part? Is there a repair manual that addresses this repiar.
Posts: 5,451 Likes: 36
Mac3216, Parts list has been forwarded. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Do you have any idea of how hard this repair is? Anything to watch out for when you take the sides apart?
Mac3216, Have you tried to take the primer off without taking the casing apart. It should have two lugs on it. If you can get a small screw driver (or thin flat metal)on the side to depress the lugs you might not have to pull the saw apart. Have a close look at the parts list that I sent you.
Bruce :
Thank you everyone. I was able to pry the bulb out without spliting the case. However, I found that all the fuel line was dry rotted. I did need to take off the left side which was about 8 screws. I could reach everthing I needed from there. The design was pretty straight forward once I got inside. I wasn't sure how far into the fuel tank the return fuel line went so I just left about 1/2" hanging on the inside. I was able to get the parts locally although they were not original replacement parts and 2' of fuel line cost me $4. My total parts expense was about $15. Once again, Thank you for all your help.
Topics12,778
Posts106,882
Members18,242
