1 members (Dandare), 4,770 guests, and 1,053 robots.
#3869 03/02/06 08:42 PM
My Victa 4013HXT (Dual cutter deck) has broken the Alloy bearing housing that holds the cutter deck drive shafts (coming down from the belt pulleys). Can anyone tell me if they are replacable at an affordable rate (and if so what are they worth?). If they aren't affordable I am considering manufacturing replacement parts from steel so the same thing doesn't happen again. Any ideas, thoughts or suggestions would be very much appreciated.
Regards
Rob
#3870 16/04/06 08:41 AM
Rhino,
Most of the Victa ride-on mowers were made by murray, so I would suggest that you check with your local mower shop as it should only cost about $150 for a complete housing. cool
Rhino #19612 31/10/10 08:13 AM
I Have a victa 4013HXT Hydro drive, that I am having problems with. It will not go forward or reverse when i use the pedal any ideas, all help would be gratefully appreciated.
Rhino #19613 31/10/10 09:08 AM
With a hydraulic transmission, if you lose drive usually the first thing to check is the fluid level in the transmission. If it isn't that, the signs are ominous.
Rhino #19633 02/11/10 10:53 AM
How do you check the fluid level as there seems to be no access to the transmission?
Rhino #19634 02/11/10 02:45 PM
As far as I know, some systems are sealed and others have a fluid tank with a cap. The best starting point is the mower's manual, but there does not seem to be a 4013 manual in the Victa list on this site. Bruce can probably help - for one thing he probably knows the manufacturer's model number (rather than the Victa model number).
Rhino #19662 04/11/10 05:14 AM
Thanks for that grumpy, I have had a look and there is no fluid tank with a cap?I have tried to look for a manual on this mower with no luck. May be Bruce can point me in the right direction?cheers.
Rhino #19676 05/11/10 06:02 AM
the model number for my mower is 40563X88A I have searched all over the net for a manual but with no luck.. frustrating. I even went to our local stockist, he had never heard of that model before!!
Rhino #19677 05/11/10 06:14 AM
You can get some fragmentary information here:
http://www.partstree.com/parts/?lc=murray&mn=40563x88A+Lawn+Tractor+%281998%29&dn=7634&dzl=14
I found it useful: I now know that you have a belt drive mower, for instance, and it probably wouldn't be all that hard to find the manual for another Murray mower that looked similar if not identical.
Rhino #20030 21/11/10 03:24 PM
Quite possibly the 4013HXT has a peerless Hydrostatic Transmission. Check for a model number on the case of the hydro. If it does there is some good help on working on it but many mower shops only want to sell you a new one since working on it can take quite a bit of time. My Victa is a 4616HXT aand while it is a murray clone it was made in the NOMA factory instead of the murray.
18,184 Registered Users
Topics12,764
Posts106,824
Members18,185
