5 members (jeffnb57, Qbar63, Brian Lincoln, Dandare, 1 invisible), 1,577 guests, and 351 robots.
by Bruce - 07/04/26 03:39 PM
Atom Spare Parts For Sale
by Bruce - 07/04/26 03:24 PM
Ryobi Spare Parts
by Bruce - 07/04/26 12:00 PM
by Bumps - 19/03/26 10:57 AM
Mower wheel ID.
Ryobi Spare Parts
Royal Enfield Mower
by Bruce - 05/04/26 03:47 PM
by Bumps - 01/04/26 04:37 PM
Mower wheel ID.
Eaton Model 6/7
Hi. I was wondering if anybody can help me. I just picked up a second hand Victa 2 stroke (Power Torque) and it runs perfectly but only for a short time before it just cuts out. The amount of time it runs varies but it always dies the same way, no coughing or spluttering, just simply switches off. I have removed and cleaned the carby and exhaust. I have tried bypassing the kill switch and this seemed to work for a little while then the same thing happened. This is driving me nuts!
The symptoms are not a good fit for fuel starvation - they are a better fit for a problem in the ignition module. You might be able to catch it playing up by testing the spark immediately after it quits - within seconds of stopping. I have never found that a reliable test though - the module can cool off and start working very quickly indeed.
If it is spark, it will either be bad grounding of the module or a bad module - unfortunately, the latter is a better fit for your symptoms. You should be able to get a replacement module from some nearby Victa abandoned on a nature strip.
That sounds like the go. I will look around for a replacement module.
Before you replace the module, you might try disconnecting the kill wire - leave the carburetor end of the wire from the module completely isolated. This is just in case the wire is shifting in the carburetor by a tiny amount after warm-up, and touching the nearby ground wire. Always isolate the kill wire and retest before you condemn a module. A bad module is more likely, but a kill wire problem is easier to test.
Qbar63, Brian Lincoln, Danny74002026, newtorestoration, Ozchick
17,911 Registered Users
Topics13,080
Posts107,356
Members17,911
PHP: 8.3.30 Page Time: 0.025s Queries: 23 (0.020s) Memory: 0.6304 MB (Peak: 0.6544 MB) Data Comp: Zlib Server Time: 2026-04-07 07:24:22 UTC
