0 members (), 1,064 guests, and 1,166 robots.
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
by maxwestern - 29/04/26 06:13 PM
by looktall - 29/04/26 02:48 PM
by AVB - 28/04/26 09:59 PM
by MowingManiac - 27/04/26 08:00 PM
Rover Rancher 1766 Ignition Barrel wiring
by RayWill - 27/04/26 06:55 PM
by vint_mow - 27/04/26 06:02 PM
Rover height adjust plate
by vint_mow - 27/04/26 08:24 AM
by vint_mow - 27/04/26 08:23 AM
by Lenoleno77 - 27/04/26 07:55 AM
#13956 26/09/09 06:13 AM
Hi all i have a briggs quantum mower. I was cleaning the carby and i assume that i blew away the needle seat because now it lets air past if you invert the carby and blow into the fuel line. This annoyed me but i did buy a carby kit from this site only 10bux https://www.outdoorking-forum.com.au/index.p...p;cPath=193_195_203&products_id=323. I assume this kit was the correct kit however it did come with the gasket for the primer bulb type carby (this carby has a choke.
do i need to get this kit https://www.outdoorking-forum.com.au/index.p...mp;cPath=193_195_203&products_id=327
Anyway onto the problem. I assume the little O-ring that fits on the needle in this photo is the seat?
[Linked Image from i184.photobucket.com]
How do i get it into the hole where the need goes? It seems that i need a lot of force is this right?
heres a few other photoes
Jeffro #13958 26/09/09 08:00 AM
Jeffro,
Here is link to the Briggs & Stratton web site so that you can download the parts list for your motor as discussed on the phone today.
Briggs & Stratton Parts List
Bruce #13960 26/09/09 08:36 AM
Hi bruce thanks for the quick responce i will be ordering the part soon.
Now onto another motor i need to find some piston rings for this engine.
In this below photo I believe its the top highlighted ringset 791098
hopefully you can see
Jeffro #13963 26/09/09 09:33 AM
I took the head off and cleaned an amazing amount of carbon off the head. The sparkplug had so much carbon on it.
started it and for about 20minutes was good but then it started to puff blue smoke.
Also when the head was off i noticed that on the compression stroke the exhaust valve opened a little and clicked... any ideas?
I forgot to measure the diametre while it was off silly me!
#13973 26/09/09 12:49 PM
the O ring is the needle seat wink
the seat relies on a press fit so yes iw would be tight to install. smile
#13977 26/09/09 03:09 PM
Now im confused one person saying it is an o-ring one saying it isnt.
Is the little o-ring that neatly fits on the needle the seat? If it isnt the seat where abouts does it go in the carby?
thanks.
Jeffro #13980 26/09/09 06:07 PM
G'day,
Just to clear up any confusion the black o ring type thing is meant to be pressed into the inlet needle housing separate of the needle. I usually use a small pin punch and press them in firm. The needle then pushes into the small hole in the o ring and cuts off the flow. The inlet needle needs to move separately to the 'o' ring (or seat).
I hope this clears up confusion, rather that confusing you further!
Regards Jay
Port Fairy Lawns and, RayWill, Matty_H95, strech, ChrisGulevski
17,937 Registered Users
Topics13,089
Posts107,391
Members17,937
PHP: 8.3.30 Page Time: 0.044s Queries: 29 (0.038s) Memory: 0.6472 MB (Peak: 0.6905 MB) Data Comp: Zlib Server Time: 2026-04-29 21:22:53 UTC
