2 members (JEH, EasyMoney), 1,512 guests, and 1,070 robots.
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
by vint_mow - 30/04/26 11:02 AM
by vint_mow - 30/04/26 10:50 AM
by looktall - 29/04/26 02:48 PM
by AVB - 28/04/26 09:59 PM
Rover Rancher 1766 Ignition Barrel wiring
by RayWill - 27/04/26 06:55 PM
by vint_mow - 27/04/26 06:02 PM
Rover height adjust plate
by vint_mow - 27/04/26 08:24 AM
by vint_mow - 27/04/26 08:23 AM
by Lenoleno77 - 27/04/26 07:55 AM
#13451 04/09/09 12:54 PM
Hi all
I am currently working on a Flymo GL47 hover mower. I cannot seem to remove the blade bolt. mad I have sprayed it with WD40 and penetrating spray but the bolt does not want to budge. Any ideas on how I could remove it? WTF
"You can't beat a good old Victa 2 stroke"
VC Victa,
Try giving the head of the bolt a good hit with a hammer as it may re-leave the thread in order to undo it. cheers2
Hi Bruce
I tried hitting the bolt several times but still does not seem
to want to come off. Do you have any other ideas.
Chainsaw Addict
For jobs like that you really need a Rattle Gun, or a Hand Impact Driver.
G'day,
Try locking the blade against the base with a pair of vice grips then get the solid bar socket thing (not the ratchet the other one) place it on the nut and hold it in position. Then tap the end (or belt it if it�s that stuck) until is comes loose. Just make sure it�s centered and square so it doesn�t strip the nut. If its still stuck whip out the blow torch and repeat what�s up there but first pre heat it and you should be fine.
This works along side Bruce�s suggestion. The sharp blows unlock the bolt. This method has never failed me with any bolt yet.
Regards Jay
Hi Jay
Thanks for the advice got the nut of with the help of a blow torch and hammer, took a little while bit it came off in the end.
Thanks for the help.
Port Fairy Lawns and, RayWill, Matty_H95, strech, ChrisGulevski
17,937 Registered Users
Topics13,089
Posts107,393
Members17,938
PHP: 8.3.30 Page Time: 0.048s Queries: 27 (0.034s) Memory: 0.6433 MB (Peak: 0.6802 MB) Data Comp: Zlib Server Time: 2026-04-30 04:37:15 UTC
