1 members (DFB), 2,639 guests, and 297 robots.
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
Early Morrison rotary mower
by MowingManiac - 08/03/26 08:09 PM
Victa Super 24/600
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
by NormK - 22/02/26 02:31 PM
by Bruce - 20/02/26 12:02 AM
Hi Folks, I have been given the job by a friend, of servicing a Victa SPX2342 Ride On Mower and the first thing I need is a Deck Belt.
It has a Briggs & Stratton Professional V Twin Engine with these specs on it:- Model Year 2013, Engine Family - DBSXS.7242VA - 724cc ECS: EM 381409
It's a 42" Deck and I'm getting conflicting advice for a local Mower shop and Google.
The Old Deck Belt that I took off is:- 3080mm and that equates to 121.26".
The Older Deck Belt that was hanging on the wall, also warn out is:- 3085mm and that equates to 121.5".
The way I measured these belts was to mark the widest part of the belt and using the wifes Sewing Tape Measure I measured out in Metres, added a mark and continued to return to my 1st mark.
The local mower shop is saying they have no listing for this belt, so I'm asking here for help..
Here's what Google Tells me:-
Victa SPX 2342
AI Overview
Based on the search results, the Victa SPX2342 lawn tractor (42-inch cut) requires specific belts depending on whether you are replacing the Transmission/Drive Belt (Engine to Transmission) or the Cutter Deck Belt (Blades).
1. Transmission Drive Belt (Engine to Transmission)
• Replaces OEM Part Numbers: 1737441, 1737441YP, or sometimes listed under generic AYP/Husqvarna numbers for these models.
• Size: 1/2" x 88-3/8" (approx. 12.7mm x 2245mm).
• Fits: SPX2342, V125, 23/42, and other 42" Victa/Simplicity models.
2. Cutter Deck Belt (42" Cut)
• Replaces OEM Part Numbers: 1757811YP, 1732956SM, or 1761268YP (depending on specific deck construction, specifically for fabricated decks).
• Size: Approximately 1/2" x 124.4" (or 118" OD depending on specific deck).
• Fits: 42" fabricated decks on SPX2342 models.
3. Alternative/Variable Speed Drive Belt
• Fits: SPX20-42, V125 23-42 (2690917).
• Size: 1/2" Wide, approximately 94.45" - 97" Outside Diameter (O.D.).
Recommendation: For the SPX2342, the most accurate replacements are usually sourced using the Briggs & Stratton part numbers, such as 1737441YP for the transmission belt.
Steve
Hi Steve,
First question is it a "B" section belt, if so eithere of the old bel sizes will be fine you are only talking half an inch difference in the length. If it is not a "B" section belt you are going to have to do a bit of guesswork
Hi Steve_2012,
Below is the parts list for your model quoting the part numbers.
NOTE: You would need kevlar type belts because of pullies riding on the back a standard cheap belt will fall apart.
Victa Model 2691235-00 _SPX2342
Thanks once again Bruce, for you great work helping me out here.. I didn't know that Part number (2691235-00) until today when I went back out there and triple checked all over the mower to see about any other numbers were on it.
I can't believe that Victa has One Parts Manual for the Briggs Engine & drive Belt, One Parts Manual for the mower and a third Parts Manual for the Deck.
But at a local mower shop today they couldn't find any pictures or part numbers for the Deck Belt or the Deck Belt Layout Diagram or even the pulleys on the deck. Except for the spindle pulleys.
Steve
Steve
Hi Steve,
Tell them to pick up the phone and ask Victa or is that two hard for them.
Hi Bruce, I went back to my local Mower Shop today with more information on this Victa SPX2342 Rideon and even with the extra information they couldn't help me out. They have suggested that I email Power Lawncare Products (who now owns Victa) and provide all the details on the mower and it's deck, included pictures and ask for Belt Part Numbers and Belt Route Diagrams to suit my deck. So I have asked for an email address in a message on their Victa Facebook Page.
The Extra Information I found, along with your help is this:-
Victa Model Number:- 2691235-00 - which you provided the parts manual for, thanks again.
Serial Number:- 2016795203
DOM:- 14/05/2023
It's a Pressed Deck and not a Fabricated Deck
That Manuals Front Cover gave me 3 - 42" deck parts numbers:-
1696407
169640700
1696541-00
The deck picture in that parts manual is not the same as the deck on this mower.
My deck has 2 x spindles and 3 pulleys close together at the read of the deck. The left side pulley is the flat belt spring loaded tensioner, the right side pulley is a flat belt idler pulley and the smaller rear pulley is the v belt drive pulley. I hope that makes sense. I have a deck picture but don't have anywhere to upload it so I can post it here.
Remembering the old worn belts are 3080mm OD, that I measured.
I'm getting conflicting information again using these deck numbers as a reference:-
1758984YP = 124.4" x 1/2"
1757811YP = 94-96" x 1/2" and at another supplier = 3111.5mm
Any further help or ideas you or any members have will be greatly appreciated..
I'm doping my best to help out a neighbour with their ride on mower.
Steve
Hi Steve,
Below is the deck parts list showing the part numbers. Also have the setup guide for the deck below.
This is the deck belt CLICK HERE
1696407-00 Deck Parts List
Deck Setup
Insomniac Extraordinaire
G'day Steve,
You can actually upload your image to this thread, in response to Bruce's response's, as long as it's within the Forum's allowances, e.g. jpg, png, etc.
To do this -> I recommend using the Full Editor choice, then click on the "Attachment Editor" option, and drag your desired image onto the pop up dialog box.
By doing this, it will hopefully further clarify for us, your issue...
I hope this info helps you,
mice_elf
Always striving for a better lawn...
Thanks to Mice_Elf, for showing me how to attach a picture of the deck on the Victa Mower I'm having trouble getting belts for.
I have attached 2 pictures and hope I have not stuffed that up..
As you can see Bruce my deck, picture 1, has an extra pulley at the rear that is not shown in the Deck Manual you gratefully provide here.
Again, ignore my attempt to refit the old spare worn out belt.
I spoke to one of the senior mechanics at my local mower shop and he has suggested I had fitted the belt wrong in this attached photo.
That's why it's way too long to fit the mower.
So the 2nd picture I have shared is what I'm hoping to be the correct belt layout.
The old spare belt that was also worn out will be the test, then I just have to find a replacement at the same length of around 3080mm OD
Time will tell..
Thanks again to you guys for helping all of us novices trying to be helpful to others..
Steve
Well done Steve_2012, the attachments look fine to me, and I guess to everyone else too...
mice_elf
Hi Steve_2012,
I suggest that you have a close look at the drawings for the model. That pulley appears to be some sort of addon because it is not shown in the drawings for the complete ride on and the deck parts list.
Good luck with trying to work it out but I myself would be looking at going back to the orignal setup and you should then get it working as it should.
Rosepetal, DF Handyman, Wayneo888!, Gerald the draught, spud 1
17,871 Registered Users
Topics13,071
Posts107,309
Members17,872
PHP: 8.3.30 Page Time: 0.044s Queries: 40 (0.037s) Memory: 0.6801 MB (Peak: 0.7618 MB) Data Comp: Zlib Server Time: 2026-03-09 09:18:53 UTC
