4 members (Dandare, xsancanin, 2 invisible), 2,553 guests, and 143 robots.
by MikeDD - 12/02/26 09:45 AM
by Bruce - 18/02/26 01:10 PM
by Bruce - 16/02/26 12:06 AM
Rover Thoroughbred Model 85
by Bruce - 15/02/26 11:59 PM
by Bruce - 15/02/26 11:49 PM
by Bruce - 15/02/26 11:42 PM
by MowingManiac - 15/02/26 12:40 PM
Victa Corvette 4016
by Bruce - 10/02/26 07:53 AM
Cox ride on
by NormK - 04/02/26 08:14 PM
Hi Folks, I have been given the job by a friend, of servicing a Victa SPX2342 Ride On Mower and the first thing I need is a Deck Belt.
It has a Briggs & Stratton Professional V Twin Engine with these specs on it:- Model Year 2013, Engine Family - DBSXS.7242VA - 724cc ECS: EM 381409
It's a 42" Deck and I'm getting conflicting advice for a local Mower shop and Google.
The Old Deck Belt that I took off is:- 3080mm and that equates to 121.26".
The Older Deck Belt that was hanging on the wall, also warn out is:- 3085mm and that equates to 121.5".
The way I measured these belts was to mark the widest part of the belt and using the wifes Sewing Tape Measure I measured out in Metres, added a mark and continued to return to my 1st mark.
The local mower shop is saying they have no listing for this belt, so I'm asking here for help..
Here's what Google Tells me:-
Victa SPX 2342
AI Overview
Based on the search results, the Victa SPX2342 lawn tractor (42-inch cut) requires specific belts depending on whether you are replacing the Transmission/Drive Belt (Engine to Transmission) or the Cutter Deck Belt (Blades).
1. Transmission Drive Belt (Engine to Transmission)
• Replaces OEM Part Numbers: 1737441, 1737441YP, or sometimes listed under generic AYP/Husqvarna numbers for these models.
• Size: 1/2" x 88-3/8" (approx. 12.7mm x 2245mm).
• Fits: SPX2342, V125, 23/42, and other 42" Victa/Simplicity models.
2. Cutter Deck Belt (42" Cut)
• Replaces OEM Part Numbers: 1757811YP, 1732956SM, or 1761268YP (depending on specific deck construction, specifically for fabricated decks).
• Size: Approximately 1/2" x 124.4" (or 118" OD depending on specific deck).
• Fits: 42" fabricated decks on SPX2342 models.
3. Alternative/Variable Speed Drive Belt
• Fits: SPX20-42, V125 23-42 (2690917).
• Size: 1/2" Wide, approximately 94.45" - 97" Outside Diameter (O.D.).
Recommendation: For the SPX2342, the most accurate replacements are usually sourced using the Briggs & Stratton part numbers, such as 1737441YP for the transmission belt.
Steve
Hi Steve,
First question is it a "B" section belt, if so eithere of the old bel sizes will be fine you are only talking half an inch difference in the length. If it is not a "B" section belt you are going to have to do a bit of guesswork
Hi Steve_2012,
Below is the parts list for your model quoting the part numbers.
NOTE: You would need kevlar type belts because of pullies riding on the back a standard cheap belt will fall apart.
Victa Model 2691235-00 _SPX2342
Cliff Tracy, The Todd, jtw37, Rod Browning, whodat76
17,855 Registered Users
Topics13,066
Posts107,275
Members17,856
PHP: 8.3.30 Page Time: 0.061s Queries: 22 (0.045s) Memory: 0.6267 MB (Peak: 0.6588 MB) Data Comp: Zlib Server Time: 2026-02-18 02:55:05 UTC
