3 members (Beefy, bigted, maxwestern), 16,848 guests, and 776 robots.
Greenfield Javelin Mk2
by Beefy - 21/05/26 06:22 PM
GX25 Honda
by NormK - 21/05/26 12:33 PM
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
Sanli height adjustment knob
GX25 Honda
by maxwestern - 21/05/26 10:49 PM
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
by NormK - 09/05/26 08:01 PM
by Bumps - 09/05/26 01:34 PM
#113646 29/12/21 03:50 PM
Just thinking last night, I got nothing for christmas............
Got a txt from a friend with facebook giveaway, got directions and bingo.
It amazes me how Santa knows exactly what we really want....
I have two motors full stroke top pull, that I put together over the years as I had the parts laying around.......
work in progress now...............................
speedy #113647 30/12/21 05:16 AM
I found one of those exact mowers years ago and it had one missing wheel too!
They were part of Victa's professional range denoted by the orange base and large fuel tank.
Wish I still had mine. Try and get the existing side pull engine going if you can. I love this model.
speedy #113680 08/01/22 12:11 PM
Just ran it before pulling it apart to service motor and molasses bath and paint base etc.
Runs OK, I'll decoke and check rings.
speedy #113682 08/01/22 07:16 PM
The head looks a bit different....
I gotta get mate to get base plate off with the rattle gun...... I can't do it.
speedy #113685 09/01/22 01:19 PM
Glad you got the side pull motor going. Didn't half rev it witless lol.
That might be the powerplus head you've got there as it's a commercial model.
speedy #113686 09/01/22 04:13 PM
I turned fuel off, they often rev a bit........ I'll put a kill switch on it later.
I'm trying to identify it. Looks like 1980's Pro 460 with side pull full crank 18".
serial number 453008044. I 'd like to get correct year.
It has LM carb. The motor shows little wear, wheels axles as well.
speedy #113699 10/01/22 01:50 PM
G'day Speedy,
It's not a good idea to use the fuel tap to turn off the mower, which is why I don't let any 2 stroke run out of fuel if I can help it. I always slip off the snorkel from the throttle and filter assembly and block it with my hand if the cut out isn't working.
From a Victa guide on fuelling and safety.
speedy #113708 10/01/22 05:44 PM
Yes I totally agree.... make proper kill switch for my Victas, , something like Norn used..
speedy #113719 11/01/22 02:36 PM
She's a brewing in the molasses bath......
Wood frame, lined with double layer black plastic, 2 lts molasses prob 40 lts water. and a cover.
Give it three weeks.... that will give me time to pick a colour.... traditional orange or go wild....
speedy #113720 11/01/22 04:09 PM
As it's a commercial model in orange, I'd go with orange again, no funky colours this time.
speedy #113721 11/01/22 05:44 PM
G'day Speedy and Mf
Going by the serial number I'd say it's a Victa Pro 460 from November the 7th 1983 .
I've had plenty of Victa 2 stroke mowers that when you turn the fuel tap off when running they do not rev up ,they
just eventually cut out but have had lots that do rev up from turning the tap off ,I would think when they rev up the
engine is running lean as air is being sucked in through the crank case seals or manifold seals leaking.
Good way to test a mower if you are buying a two stroke ,don't buy the mower if it revs up from turning
the tap off when running, although I do agree 2 stroke mowers should not be stopped by turning the tap
off.
speedy #113725 11/01/22 07:58 PM
I hope you get yours looking like that speedy.
How did you decipher all that maxwestern?
speedy #113726 11/01/22 09:07 PM
The first 3 digits in the number Mf ,453 / three is the last part of the year but you need to know the decade then
45 is week 45 of 1983 .
speedy #113727 11/01/22 09:11 PM
Max, I had never thought of that aspect with regard to the seals causing rev increase.
I admittedly run them out mostly (ie when I hear the motor tone change as it begins to lean out i shut it off), but I do have a FC tilt a cut that will absolutely rev it guts out before dying.
As it is a mongrel to start, I think I will pull the seals
Edit - Max answered While I was typing
MF, I think Max correctly analysed the code speedy posted 453008044 - means 45th week of 1983. Which started Nov 7 1983
speedy #113728 12/01/22 12:29 AM
Goodness me, I was in year four drawing pigs in class!
speedy #113732 12/01/22 06:45 AM
Thanks Max, and I won't be turning fuel off on my 2 strokes... I'll make kill switches....
Or this old fashioned kill switch idea .
speedy #113752 13/01/22 05:15 PM
Yes it does sound like the seals have gone Tyler (hard to start and over revving)
If I buy a new rubber plug for the original kill switch wires then I generally don't have any more
problems with the kill switch Speedy but a separate switch will work fine too.
I too have found a couple of twins 1983 .WP152AO
Drawing Pigs you say in 83 Mf, yes I too was drawing portraits of teachers in class .
Arguing With a teacher is like wrestling with a pig in mud sooner or later you realize the pig likes it. smile
speedy #113896 24/01/22 06:05 AM
It's been in bath for 13 days, just checked and turned handles over so ends will get treated..
Looking good..........
Motor is ready to put together..
Got the Rustolium paint. I use that stuff because when it dries , spilt petrol doesn't disolve it, like ordinary paints.
speedy #113983 03/02/22 02:05 PM
Got some paint on the parts. Just finish painting and assemble....
speedy #113989 04/02/22 07:01 AM
Used Black Zink spray. thought it's gotta protect a bit.
speedy #114015 06/02/22 05:28 PM
preview. my girl picked colour as it's hers.....
speedy #114016 06/02/22 09:22 PM
Paint job looks professional enough, a shame about the choice of pigment.
What undercoat was used if any? I know, Rustoleum supposedly doesn't require primer.
speedy #114021 06/02/22 11:37 PM
Thats the second pink utility on here https://www.outdoorking-forum.com.au/forum/u...-utility-paintwork-design.html#Post32598
My sentiments echo MF's Speedy - great job - shame about the colour. Unique though, and sure to put a smile on her face
speedy #114024 07/02/22 01:59 AM
May as well put heart stickers and glitter over it while we're at it. Dried mud and grass won't look good on it though.
speedy #114025 07/02/22 06:07 AM
I thought it might raise an eyebrow. And MF I didn't use primer. Just two coats of Rustolium..
I'm planning next paint job for Pope, the correct one persimmon orange.
speedy #114030 07/02/22 03:39 PM
Nah speedy, looks good and it's going to a lady after all. She'll like that.
speedy #114056 09/02/22 01:51 PM
Just got to put a kill switch on. Mowed the front lawn this morning. Went well. I put another muffler on as old one was split, shutdown well.
speedy #114059 09/02/22 04:10 PM
You've given that mower a new lease on life. Just drum it into her that the two stroke oil in the fuel is it's oil supply for engine lubrication.
Hope the butterflies can stand up to petrol spills wink
Nice touch haha.
Redgum102, JOBPOF, nktapps, nglfm, KimmyGib
17,965 Registered Users
Topics12,729
Posts106,671
Members17,966
