Search OutdoorKing by entering Key Words Below
1 members (Jeffery), 357 guests, and 63 robots.
Victa Pro 550 Mulch
by Jeffery - 26/05/24 07:43 PM
Husqvarna Rancher 50 Oil Vent
by MowingManiac - 18/05/24 11:23 AM
Two hardly used chains for Ozito 18 volt chainsaw.
by MowingManiac - 07/05/24 06:50 PM
Honda GX160 only runs for a few seconds
by MowingManiac - 04/05/24 05:33 PM
Rover Easypush lower handle arm rhs
by Wram - 26/04/24 07:28 PM
Ogden power push mower
by JEH - 12/03/24 02:50 PM
Victa Pro 550 Mulch
by Jeffery - 01/06/24 11:09 PM
Victa: The Triplets
by maxwestern - 30/05/24 10:40 PM
by maxwestern - 23/05/24 01:00 AM
by MowingManiac - 11/05/24 07:22 AM
by maxwestern - 08/05/24 08:11 PM
Victa Imperial Project
by NormK - 07/05/24 06:17 PM
by Wram - 06/05/24 08:15 PM
#113431 27/11/21 05:12 PM
Hi Guys
I've have a briggs 8hp on a rover colt that I bought a few weeks ago.
I've replaced the coil, carby and given it a freshen up but I can't get it to run smoothly. It almost runs as though it starves for fuel intermittently. I've had the same issue with both the new and old carby. I've gotten it to slightly improve with giving it a tune but it does continue. Some of the head bolts weren't all that tight which I only noticed the other day but I'm not sure if that would have any bearing on it.
It does seem like after 5 or 10 minutes of mowing it seems to gradually get smoother. The governed appears to hold steady it just sounds almost like I'm sticking my hand over the air intake about every 5 or 10 seconds.
Membership information
Hi gizmo1993
https://www.lawnmowerfixed.com/mower-engine-surging/
The most common reasons for a surging
Bad Fuel
Bad spark plug
Dirty / faulty carburetor
Fuel filter blocked
Fuel tank blocked
Fuel line blocked
Gasket vacuum leak
Manifold vacuum leak
Governor control fault
You can apply a half choke with the engine running if you have a motor without a choke holding a finger half over
the carby intake will do once the air filter is removed.
If the engine now runs without surging – Gas starvation is the likely fault. If it runs just the same .A vacuum leak is the more likely fault.
Nealy, Pete1nlancs, Ron R, catthewhde, Mypwta
16,805 Registered Users
Topics12,718
Posts104,655
Members16,805
Most Online2,545
Dec 23rd, 2019
Powered by UBB.threads™ PHP Forum Software 7.7.5
(Release build 20201027)
PHP: 7.4.33 Page Time: 0.014s Queries: 20 (0.010s) Memory: 0.6648 MB (Peak: 0.6900 MB) Data Comp: Zlib Server Time: 2024-06-02 19:52:30 UTC
