0 members (), 13,200 guests, and 1,761 robots.
I picked up a TAS powered outboard yesterday, it was a versatile engine and was used on all sorts of outdoor equipment including mowers.
I put the Victa tank on as the one it had was plastic and broken, any ideas on what the original carb was ? Mine has a Chinese one fitted at the moment. Last question is how many cc's ?
Got it running and it dumped about 10 years worth of oil scum out of the exhaust
[video]
[/video]
These are an interesting little engine/outboard.
Unfortunately I don't have any in my collection and therefore don't know much about them. That said, I see you're already speaking with Notav8 on another forum. He's a good guy an should be able to help you out.
AusAnzani
Paul_c has probably found this already, but here's a YouTube vid of one of these running
[video]
[/video]
I ran it some more today and it was putting out less smoke. Pulled off the barrel to check the rings because it was hard to start, they are worn and the bottom ring had less wear so I swapped them over and now it's starts first pull even when hot :-). I have ordered a set of rings from the Outdoorking store. Information for future reference is below
Engine size is 22 cc, piston size is 35mm, rings are 2mm wide approx 1.51mm thick
Original part number is 04100000212
Replaced by part number 6686116
Current part number is 0410000021
Tanaka still make outdoor equipment and the 22cc engine is in use in a modern form. Rings are $17.85 each, 2 required.
https://www.outdoorking-forum.com.au/index.p...1084fc568&keyword=Tanaka+piston+ring
Expensive little suckers but good that genuine rings are still available and in Australia.
I would like to find a better muffler, mine is fairly rusty on the exterior.
Hi Paul
I am amazed that you tracked down the parts.
Do we have a model number for your engine?
It is clearly relevant as I think this engine was used on lawnmowers,
as you have said. At 22cc, this could be the smallest mower engine!
I like the word 'TAS' ... reminds me of a great State.
Hi Jack, Tassie is a great state. One I would like to visit soon, the model is TOB 120
T for Tanaka
O for out
B for board
120 for 1.2 hp
Tanaka have an easy system TCS is Tanaka Chain Saw and I think the numbers are hp etc. I found they were the correct rings due to another site listing the models that they fit QCP121 is a water pump. Same engine as the outboard and mower
http://www.manualslib.com/manual/168073/Tanaka-Qcp-121.html#manual
Villiers also made a Tanaka engine in 1966 under licence, the P7. Here is an example of the engine fitted to mini bikes
The P7 is a very useful engine
http://jleibovitch.tripod.com/id95.htm
Tanaka history
http://www.tanaka-usa.com/main-navigation/company/history
I did a lot of cross referencing this afternoon, might be able to purchase a newer style of muffler ?
Hi Paul
It's just amazing what's out there.
You have given us some great information there. Thank you.
The lawnmowers of interest are the Walmac & the Minimaster.
I can find little on each.
Minimaster:-
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=51786
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=28631
Walmac:-
I have the engine sorted out now, stripped down and cleaned, cylinder honed and replacement rings fitted. I obtained the correct fuel tank, carby and a better muffler.
[video]
[/video]
Next is the leg and then a repaint :-)
SantaAnaWinds, JinxJuno, Kenniffs, Neill M, Peenuke1
18,243 Registered Users
Topics12,778
Posts106,883
Members18,244
