Search OutdoorKing by entering Key Words Below
1 members (Infus10n), 270 guests, and 70 robots.
Victa Pro 550 Mulch
by Jeffery - 26/05/24 07:43 PM
Husqvarna Rancher 50 Oil Vent
by MowingManiac - 18/05/24 11:23 AM
Two hardly used chains for Ozito 18 volt chainsaw.
by MowingManiac - 07/05/24 06:50 PM
Honda GX160 only runs for a few seconds
by MowingManiac - 04/05/24 05:33 PM
Victa 24 F/C crank pulleys
by NormK - 02/05/24 04:56 PM
Rover Easypush lower handle arm rhs
by Wram - 26/04/24 07:28 PM
Victa: The Triplets
by maxwestern - 30/05/24 10:40 PM
Victa Pro 550 Mulch
by Jeffery - 29/05/24 07:53 PM
by maxwestern - 23/05/24 01:00 AM
by MowingManiac - 11/05/24 07:22 AM
Ogden power push mower
by maxwestern - 08/05/24 08:11 PM
Victa Imperial Project
by NormK - 07/05/24 06:17 PM
by Wram - 06/05/24 08:15 PM
by NormK - 03/05/24 04:59 PM
wce Offline OP
Hi all
Thought I would see if the Sunbeam with Kirby/Tecumseh 2 stroke would fire up. Wound up the starter, spring seams fine but the trip release is slipping, took the starter off and the casing around the release dog is cracked. Found some great info on the site as usual which suggests the problem with this starter is not a serviceable one and Ill be looking for a complete replacement. Could someone please confirm my fears ?
Many thanks
wce
Membership information
Would a Victa one fit?
wce Offline OP
Hi Mowerfreak
That was my first thought, I'll borrow the one off the Corvette just to see if the Sunbeam starts. To the naked eye they look the same but the Victa didn't fit the bolt pattern of the Sunbeam. The diameter of the base at it's widest which is the outer edge of the bolt posts is 10mm wider on the Victa. The only other thing i noticed was the part protruding from the centre of the Victa, other than that they look the same. I guess you could slightly bend in the post's of a Victa and it should fit but will give it a slight height increase and whether that would be problematic with meshing i'n not sure but it would only be slight. I won't be doing it to my one and only as an experiment though.
wce
Hi wce not surprised at all. All wind up starters I've seen, look the same as each other at first glance, but a ruler says otherwise.
Sourcing another one of those is going to be hard, unless other brands used it as well. Maybe there's a rope starter and cup that will fit.
wce Offline OP
Hi Mowerfreak
If I can't source the correct one ( I agree will not be easy ) I will try get a Victa and modify to fit and see how it goes. Made up a rope pull for it this afternoon and she made some right noises. Hard to know the correct throttle position as the original lever is't there but suspect the carb requires internal cleaning as well. Will post for assistance on that issue as have 0 experience with this motor.
wce
wce Offline OP
when I went back to the boardroom to give the Corvette it's starter back I had another look at both and definitely the bolt posts on the Sunbeam are more vertical than the Victa. Can't see a reason why a Victa can't be installed but then again .............................................................
wce Offline OP
found one for sale and the colour of it would strongly suggest Victa, chap didn't have a clue what it came off so I asked him to take the diameter measurement and it's the same as the one that came off the sunbeam 160mm so should bolt straight on.
The number on the underside of the sumbeam starter is 132D259 ESS3-3. The number on the one I am getting is 132D259 ESS3-4. Unfortunately I can't make out the number on the Corvette. Anyone got a starter lying about to have a look at the number ?
wce
wce Offline OP
Hi all
Just an update on the starter. The one I found for sale arrived but unfortunately the chap didn't measure correctly and the bolt pattern is same as Victa. The positive at this point was that at least I had a working spare. I put the Sunbeam and Victa units side by side on the bench and after a detailed visual examination all over came to the conclusion that the only difference was the angle of the mounting posts and a pin of some type that protrudes from the centre of the retaining nut for the top coupling ( please refer to pics posted previously ). If someone knows the purpose of this I would love to know as the Sunbeam doesn't have one. The pin protrudes just far enough that it contacts the engine top when the starter is sat in position. The pin is slotted in the middle so presuming it was not a fixed item I gave it a few light taps with a soft punch and it did move so I tapped it back to being flush with the nut head which resolved the clearance issue. I next inverted a 12 inch crescent spanner in the vice as the jaw is a good fit over the width of the starter post mounts and bent them to the vertical position, squared the mounting feet on the anvil and the starter fits straight on and works fine. The whole issue is a bit confusing and with the numbers on the underside being different by 1 digit on what i now consider to be the same units only ads to it.
Anyway, I hope this information may help another member if they encounter the same issue. If someone has a victa impulse starter about the place can you please check the number on the underside and post to compare with the numbers in the above post.
wce
I have an impulse starter that came attached to a Victa Kirby VK30 engine. It might not have been from a Victa originally, but it does fit. The number on the underside is GED 259 ESS2.
wce Offline OP
Hi suebutcher
Thank's for the information
wce
Pete1nlancs, Ron R, catthewhde, Mypwta, Routten
16,804 Registered Users
Topics12,718
Posts104,653
Members16,804
Most Online2,545
Dec 23rd, 2019
Powered by UBB.threads™ PHP Forum Software 7.7.5
(Release build 20201027)
PHP: 7.4.33 Page Time: 0.028s Queries: 37 (0.017s) Memory: 0.7208 MB (Peak: 0.7984 MB) Data Comp: Zlib Server Time: 2024-05-30 18:04:28 UTC
