1 members (1 invisible), 3,120 guests, and 474 robots.
by MikeDD - 12/02/26 09:45 AM
by NormK - 12/02/26 08:11 PM
by NormK - 11/02/26 05:35 PM
Victa Corvette 4016
by Bruce - 10/02/26 07:53 AM
Rover Thoroughbred Model 85
Cox ride on
by NormK - 04/02/26 08:14 PM
by NormK - 02/02/26 08:30 AM
Page 3 of 7 1 2 3 4 5 6 7
Full cranks are dead easy to fit the kill switch, I use a round one that fits in the existing hole in the steel cover above the carby and the earth wire from the switch I just put on the steel cover with a pop rivet. It is good when they start so easily and come back to idle and not revving the guts out of it and a nice tickover at idle when you go to empty the catcher. The G4 cam is a bit of a pain because of it not having the kill switch ramp. One thing you have to be careful of is to not pull back on the throttle too hard because you can pull the cable out of the cam and this splits the cam.I am putting a stop in the air filter housing to stop this happening.The six mowers I got a couple of days ago all rev way too high so I have to modify all of those to get good throttle control
You must have it down to a routine NK, but it was quite a learning curve for me ( though nowhere near like you, who had to come up with it). My next one will be much easier and better than this one.
Regards the kill button placement, I was considering that hole only to remember it's for the vacuum tube from the decomp valve. So you just blank it of at both ends and not bother with it?
MF you still need the decomp hose hole, the other hole is further forward. I usually don't run the decomp hose through the cover because it is too messy, trying to get it connected up and hoping it doesn't come off while you struggle to get the cover into place.Sometimes I have cut a slot up to the hole so the hose can be put in place and then the cover can go straight over the top. It is easy to see why Victa wanted to design the Powertorque because just fitting this in a production situation is just too time consuming, this part of the production line would have been a bottleneck. As you can see in this pic the hose is run up inside the cover and the governor fitting has just been removed
I soldered the wires on only to have a d'oh!! moment when I wanted to fit a bracket and realised I could no longer fit the nut and washer or put it though a hole.
My soldering skills aren't exactly above par, so I used a zip tie to mount it vertically to avoid having to de-solder and attempt to re-solder such intricate electrodes again. I quite like this solution as it lets the wires hang in their natural state and looks quite tidy for what it is.
MF, why would you put the carby on facing that way, you can't get at the primer cap and with them around that way the snorkel sticks out too wide and gets caught on everything. I hope that is not a latching switch, because you will get caught out not knowing if it is on or off, I use the momentary ones where when you let it go it is ready to start again.
Don't worry, it's a spring one you have to hold down to "turn on" the kill.
Unfortunately it has to face that way because it's on a . VC-160 frame which doesn't allow enough clearance for a right hand snorkel to fit between the frame and the fuel tank. I wanted to use the opportunity to try your carby mod on a charity case like this Franken-mower I found, and I don't have the original left hand snorkel for this configuration, so made do with stuff I had lying about. Yes it sticks out too much but it stays in place and I'll replace it down the track + watch extra carefully where I'm going! This project was mainly to learn.
OK you're forgiven. I picked up another Powertorque today from Gumtree and the bloke told me he couldn't get it started. When I got home it was obvious why, the primer cap was upsidedown, but at least it had a full tank of fresh fuel in it, runs fine but as usual needs the carby mod done
I gave Frankenmower a longer test today and it took only four pulls with the throttle moved up to medium to start, without pushing the hard to reach primer. I think I will fit a G4 grey primer-less cap to this one if it keeps starting this well from cold, and save the white cap for when it can be more useful.
It went well but I'll have to watch more carefully how I trim the cam next time, as I definitely shaved to much off. I had to file away a bit of the bottom of one of the spider legs to clear the screw on the cam as it rotated and lifted the spider up!
I'm grateful it goes despite that, but the result is most of the throttle rise occurs only in the first quarter of the t bar movement and the rest of the way, it rises just a little bit more to max revs.
MF what you can do with the G4 cam is you can adjust it so that when the cam is up against the stop/bolt the 3 leg lifter is sitting on the highest points on the cam. You can get this exactly in the right spot by adjusting the screw in and out
I did that as best I could and carefully observed each leg of the three prong lifter. Problem is that I cut too much off one of the ramps on the cam, so I had a situation where the legs on the other two were starting to lower again, but the third leg still hadn't reached its peak, so I had to have a compromise. Also, I didn't have much thread protruding by the time I adjusted the G4 cam screw.
I'm quite happy with the result anyway. I'll do a better job next time.
I made up 14 of those primer caps a month ago, and I just used the last one, no wonder I'm going through needles like there is no tomorrow.
That's a good indicator of how many you are moving!
That is 40 days since I made them up, there is still a few waiting to be sold so it probably works out to one going every 5 days but on average it takes me at least 2 days to get them repaired and sorted properly so it works out about right
Did a carby on a full crank this morning and it still wants to rev like crazy and I can't see any reason for it, I'm guessing it has to be something wrong with the carb body
Changed the body and used the same internals and it works fine, now I have to set the problematic body up with another set of internals to prove if the body was the problem
You may have made a blunder in assembly, but may be a hairline crack in the body?
Had it apart a couple of times couldn't see anything wrong, I will put it on a PT sidethrow slasher that belongs to a mate and see how it goes. I told him last night that I want it gone because I have had a number of people here asking if it was for sale. I have one here with a full crank but the base is rusted out and they are getting a bit scarce on the ground now
I had a bloke come and get a PT a couple of days ago and he brought his old PT for me to look at. He bought it new 25 years ago and it had only had new blades fitted a number of times, but sadly I think it will end in the dead motor pile
Ok MF, I fitted the carby to the sidethrow and it behaved erratically, didn't rev hard like it did on the other motor but had to keep opening and closing the throttle to keep it running. Changed all the internals to another body and it works perfectly. This is only the second body I have come across that had a problem and just would not work, apart from the obviously damaged/broken ones.
Will my mate appreciate the effort I put into it? probably not but he will say thanks because he always does. Not only that he would have to be the only contractor running around with the oldest collection of old Victas mowing lawns in the inner leafy suburbs of Melbourne. And he is still pressuring me to fix an old full crank 550 self propelled I have here for him. He says the looks he gets from other contractors is priceless
Only a billion or so more out there. No great crisis. It was interesting to find out though.
It is indeed unusual to see Victa two strokes being used by mowing contractors/ runs.
I'd be a bit concerned about the fumes day in day out, but I don't imagine four strokes have catalytic converters either.
Councils used high output powertorques for years in their commercial grade equipment.
Thought I would add this in here, I dodgily added a missile style switch and cover (had to reverse the contacts to the body) up to the air filter housing with some flexible round black speaker cable, and crimped on some spade terminals to the existing kill wires since the long terminal snapped off from the wire. I will crimp some spades on to some lengths of wire with the victa kill pins on the other end so I can install them in to the carb before it is refitted, then plug the wires in to the other ends when the carb is back in place. Should eliminate fiddling with the kill wires if and when they ever go back in. I used a champion brand 10mm vacuum cap to go over the spigot in the carb body, all works well. I had to give the body and jet a good run in he ultrasonic cleaned as I was having starting problems again. Starts first easy pull now. I may try and insulate the back end of the switch a bit better, mount it to a bracket and run the wires in the snorkel if I get really bored at some point.
Stillsearchn, ataranto, MikeDD, urban, jenny paul
17,847 Registered Users
Topics13,065
Posts107,262
Members17,847
PHP: 8.3.30 Page Time: 0.063s Queries: 59 (0.054s) Memory: 0.7396 MB (Peak: 0.8675 MB) Data Comp: Zlib Server Time: 2026-02-13 03:14:55 UTC
