3 members (bigted, Red Rum, 1 invisible), 2,355 guests, and 293 robots.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
Early Morrison rotary mower
Shout Box
by Bruce - 16/03/26 08:10 AM
by geobee - 15/03/26 05:27 PM
Victa Super 24/600
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
Hello
I am having a problem with my Villiars mark 10 (v carby) stationary engine, which is running a small concrete mixer. It will only run with the strangler closed. If I open the strangler, after warm up, the engine cuts out. Does anyone have any ideas?
Here is the manual. Be sure to set the carb needles etc as shown
http://pistonpumps.com.au/documents/VILLIERSMK10AND12OPSMANUALJULY1957.pdf
Let us know how you go.
Hello Millzy 555
I found the manual some months ago and set the carby as per instructions, so I think there has to be another reason for this problem, but thanks for your interest and advice.
Hello Chesh and Millzy
The symptoms you describe suggest a carby overhaul is needed.
Setting the carby is the first step in diagnosis.
Next step - carby overhaul and re-set as per Millzy's advice.
All the basic checks should be carried out first -
compression, spark, fuel ...
The initial suspect - after the basics - lies with fuel.
Please tell us how you go.
Many thanks to Millzy for the link.
Hello Millzy and Jack,
I've cleaned the fuel tank, filled up with fresh unleaded fuel? { hope this could not be the cause.} the compression is 100pc, and has a good strong spark, it seems the only thing left is to pull the engine out, put it on the bench, and start work on that Carburetter. I will keep you posted. Thanks.
Hello all,
I would go through the carby and give it a good clean, gaskets are available from John at rusticspares.com.au if the engine was on a mixer it is probably set for running that load and will need a bit of attention for running light. Also give the air filter a good clean out as the gauze is usually blocked up.
Must be running very lean
Hello Paul
You make a good point, will do! Thanks.
Hi Millzy, I removed the air filter, sprayed Nutcracker into the port, replaced the filter, problem solved, the Engine is running great. Thanks for your interest and advice.
Hi Paul, I removed filter, sprayed Nutcracker into the port, replaced the filter, and the Engine is running great, Strangler open. Thanks for your interest and support.
Bowzie, Rowie_77, johnny rotten, SBColllector, JTB
17,880 Registered Users
Topics13,073
Posts107,317
Members17,880
PHP: 8.3.30 Page Time: 0.038s Queries: 33 (0.032s) Memory: 0.6565 MB (Peak: 0.7057 MB) Data Comp: Zlib Server Time: 2026-03-16 13:19:51 UTC
