2 members (JEH, EasyMoney), 1,512 guests, and 1,070 robots.
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
by vint_mow - 30/04/26 11:02 AM
by vint_mow - 30/04/26 10:50 AM
by looktall - 29/04/26 02:48 PM
by AVB - 28/04/26 09:59 PM
Rover Rancher 1766 Ignition Barrel wiring
by RayWill - 27/04/26 06:55 PM
by vint_mow - 27/04/26 06:02 PM
Rover height adjust plate
by vint_mow - 27/04/26 08:24 AM
by vint_mow - 27/04/26 08:23 AM
by Lenoleno77 - 27/04/26 07:55 AM
#704 30/09/06 08:45 PM
Hi bruce, I have a weedeater,brushcutter that wont idle indefinitely, when it is warm with no choke it runs great, but when it is left to idle with no throttle it slows gradually and then just stalls.
Any ideas?
thx jesse
#705 30/09/06 09:09 PM
jesse43,
I need you to have a look at the carby and see if it has Mexico stamped on it. If so you will need to remove the fuel screen on the pump side(the side with just one screw). This will help fix your problem. eek
#706 30/09/06 09:27 PM
Originally posted by Bruce:
jesse43,
#707 30/09/06 09:29 PM
Hi Bruce it has WALBRO written on it and singapore stamped in it.
thnx jesse
#708 01/10/06 10:17 AM
jesse,
Ok you will need to take the muffler off and check the exhaust port for carbon build up. If it has any blockage clean it out(make sure that the piston is covering the hole so no carbon falls into the cylinder). woot
Once you have done these things let me know if you still have a problem and we will go to the next stage. devilchilli
#709 24/11/06 02:00 PM
Hi I have done what you said and there are blokages so what should i do next?
Thanks jesse
#710 24/11/06 02:03 PM
sorry I meant no blokages
#711 24/11/06 03:48 PM
jesse43,
1. OK have you replaced the fuel filter in the tank?
2. If you haven't then replace it.
3. Try that to see if it makes any improvement. :Wavey:
Did you make any adjustments to the high & low screws?
Also are the screws tight on the cylinder? confused
Port Fairy Lawns and, RayWill, Matty_H95, strech, ChrisGulevski
17,937 Registered Users
Topics13,089
Posts107,393
Members17,938
PHP: 8.3.30 Page Time: 0.042s Queries: 30 (0.034s) Memory: 0.6506 MB (Peak: 0.6942 MB) Data Comp: Zlib Server Time: 2026-04-30 05:56:27 UTC
