2 members (looktall, 1 invisible), 1,716 guests, and 1,295 robots.
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
by AVB - 28/04/26 09:59 PM
by MowingManiac - 27/04/26 08:00 PM
Rover Rancher 1766 Ignition Barrel wiring
by RayWill - 27/04/26 06:55 PM
by vint_mow - 27/04/26 06:02 PM
by vint_mow - 27/04/26 08:31 AM
Rover height adjust plate
by vint_mow - 27/04/26 08:24 AM
by vint_mow - 27/04/26 08:23 AM
by Lenoleno77 - 27/04/26 07:55 AM
YardKing 4 stroke spare parts
#6667 10/12/07 12:18 PM
I have a Ryobi Lawn Hornet - Model RLH1100 MK111 with a jammed pull start cord. Can anyone tell me how to remove the clutch rotor assembly to access the recoil pulley assembly?
Hoping you can help
Bryan
Bryan,
You will need a T20 screw driver to remove the clutch drum as you have a screw in the center of the drum. cheers2
Bruce,
Thank you for your reply. I knew about the screw in the centre of the clutch drum assembly and it has been removed. My problem is how to remove the clutch rotor assembly from the shaft to allow the starter housing to be removed to access the recoil pulley and starter rope. Hope you can assist.
Bryan
Bryan,
Ok to remove the the clutch you will need something like a brass dolly and hit the clutch in an anti clockwise direction and it will undo.
Then remove the four screws on the housing and you will be into the starter area. cheers2
BRUCE
MANY THANKS FOR YOUR PROMPT ASSISTANCE.
BRYAN
Bryan,
Did you get the clutch drum off? cheers2
Port Fairy Lawns and, RayWill, Matty_H95, strech, ChrisGulevski
17,937 Registered Users
Topics13,089
Posts107,389
Members17,937
PHP: 8.3.30 Page Time: 0.069s Queries: 27 (0.062s) Memory: 0.6411 MB (Peak: 0.6773 MB) Data Comp: Zlib Server Time: 2026-04-29 02:21:02 UTC
