Just a bit of info on these Buzacott [also sold as Rosebery] hopper cooled single flywheel stationary engines.
I did an overhaul on a 3HP Buzacott as a project in an 'Automotive Practices' subject in secondary school, back in the '70s. The teacher wanted to set one of these old open flywheel engines up with a flywheel brake, to demonstrate measurement of horsepower and torque using a spring balance! Our family business included farm machinery sales, and we picked up one of these engines from a customer's farm for the sum of $5, to donate to the project.
These were actually built as a kerosene engine, with a very primitive floatless 'suction valve vapouriser', not a true carburettor. The main tank was for power kerosene, and there was a small 'starting cup', with a pivoting cast iron lid, mounted off the side of the carby. That's the type fitted to the green engine in CyberJack's first post, and the fuel tank is in the original position there, for suction feed. The higher tank position would have been necessary to use a gravity feed carby.
To start the engine, the main manual needle fuel valve at the venturi was closed, and the cup filled with petrol. Then you swung on the [detachable] crank handle to get the engine to starting speed. You made sure you didn't wrap your thumb around the handle, in case of a kickback!
It was then a matter of letting the engine run until it started to misfire as the petrol ran out, and then opening up the needle valve until it ran smoothly. By then the cast iron inlet tract would be warm enough to vapourise the kero; it was an en-bloc casting with the exhaust outlet.
They were a governed engine, with a centrifugal governor controlling the magneto timing. The governed speed range was in the region of 750-1000 rpm. Speed control was by adjusting a preload screw, on the external governor spring.
There are a couple of pics with the bits labelled
HERE As CyberJack says, these engines had very poor power-to-weight ratios; they were built for longevity and reliability in rural conditions.
