2 members (Dandare, 1 invisible), 2,437 guests, and 258 robots.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
Early Morrison rotary mower
Shout Box
by Bruce - 16/03/26 08:10 AM
by geobee - 15/03/26 05:27 PM
Victa Super 24/600
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
The pilot jet has been the culprit more than often with these carbies when it comes to surging . I spend a lot of time cleaning the carby as I find that's where most of the problems are . That Victa looks great. When running right they start very easily.
I'm sure you know, Mark, you must never use a spark plug of different "reach" (thread length) from the original one. If you fit a shorter reach plug (which had been done to this engine before you owned it) the spark will be occurring outside the combustion chamber and at best that will retard the ignition, but it may prevent it from firing at all. Furthermore the spark plug thread in the cylinder head will carbon up so you can't put the correct reach plug in without stripping the thread in the head, unless you re-tap it with a special tap - the thread is standard for spark plugs, but its pitch is intermediate between 14 mm fine and 14 mm coarse. It is even worse if you use a plug of longer reach than standard: the piston may hit it, with dire effects on the piston, and even if it doesn't, the part of the thread that extends into the combustion chamber will carbon up and it will become impossible to unscrew the spark plug without stripping the thread in the cylinder head. Short summary: use the correct plug, and when you obtain a second-hand engine, check the plug as part of your initial inspection before you start it.
The Honda carburetors are a bit prone to gum formation, especially in the emulsifier lateral holes, and they will run badly at off-idle and intermediate speeds if you don't rectify this. The main jet also builds up gum, but moderate build-up seldom has much effect except for making them over-sensitive to choke setting. Unless you get the main jet back to its original size of about 0.55 mm, you'll find you can't open the choke fully immediately after cold start. I once put up with that for a couple of months with a GXV140, thinking it must be one of the effects of the US emissions calibration, but then I measured the jet and found it was 0.45 mm. I gave it a short blast of carburetor cleaner and it suddenly was 0.55 mm, and I could open the choke immediately after cold start even in the middle of the Melbourne winter.
Thanks Roebuck and Grumpy,
Yes, I will pay more attention to the next one of these carbs I clean.
The plugs listed in the GXV120 Manual are BP5ES & BPR5ES - also W16EP-U & W16EPR-U.
I have a BP5ES in the V40 ATM and it is running great.
I have never considered all of the implications of using the right reach plug before, so thanks for that.
I did fix a Techumseh engine once that had a long reach plug in it with the piece of metal snapped off the end, there were small dints all over the piston crown and around the valves.
This has been a great learning experience fixing these Chondas, I am a bit more confident now. I think they run quiet and strong, I like them.
Today I striped down 2 x HRU195's. I will start another thread, it will help me and others I hope.
Mark.
Thanks for contributing this thread Mark, I think it will turn out to be popular for a long time to come. I keep saying we will all end up running chondas, so it is in our interest to find out something about them.
I'll close the thread, and follow your new one with interest.
Bowzie, Rowie_77, johnny rotten, SBColllector, JTB
17,880 Registered Users
Topics13,073
Posts107,317
Members17,880
PHP: 8.3.30 Page Time: 0.043s Queries: 23 (0.037s) Memory: 0.6402 MB (Peak: 0.6659 MB) Data Comp: Zlib Server Time: 2026-03-17 04:42:24 UTC
