0 members (), 1,080 guests, and 982 robots.
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
by vint_mow - 30/04/26 11:02 AM
by vint_mow - 30/04/26 10:50 AM
by looktall - 29/04/26 02:48 PM
by AVB - 28/04/26 09:59 PM
Rover Rancher 1766 Ignition Barrel wiring
by RayWill - 27/04/26 06:55 PM
by vint_mow - 27/04/26 06:02 PM
Rover height adjust plate
by vint_mow - 27/04/26 08:24 AM
by vint_mow - 27/04/26 08:23 AM
by Lenoleno77 - 27/04/26 07:55 AM
G'day to all, chook's the name
I recantly purchased a victa 18 at a garage sale for $5 and it has a very weak almost none existant spark, so i guess ill start with a new coil, condensor, points, and spark plug.
Where would be the best place to purchase these and what should i expect to pay?, also what is the correct heat range spark plug?
cheers chook...
P.s ill post some pics as soon as she is back together and runing.
chook,
Before you go buying any parts I would be doing the following:
1.Clean the points with emery paper
2.Clean the flywheel magnets with emergy
3.Clean the earth contacts (where the 'E' plate sits on the engine)
Then check what the spark is like with a new plug. bigshock
The cost of points & condensor would be about $14 max and the coil would be about $30+. cheers2
thanks for the reply
1.Clean the points with emery paper yep done that
2.Clean the flywheel magnets with emergy done
3.Clean the earth contacts (where the 'E' plate sits on the engine) ill try that but it's pretty darn clean in there
The cost of points & condensor would be about $14 max and the coil would be about $30+. cheers2 [/quote]
Chook,
Are the points pitted? confused
If so you will have to replace them. woot
The coil should be the last thing that you replace as it is the most expensive. cheers2
Port Fairy Lawns and, RayWill, Matty_H95, strech, ChrisGulevski
17,937 Registered Users
Topics13,089
Posts107,393
Members17,938
PHP: 8.3.30 Page Time: 0.035s Queries: 22 (0.031s) Memory: 0.6343 MB (Peak: 0.6590 MB) Data Comp: Zlib Server Time: 2026-04-30 09:52:06 UTC
