1 members (Gizmo),
1,152
1,516
g'day. name's glen and after a long while without one i have another viccie. last one had a steel base and i believe a 148cc donk. moving meant parts were stolen from work where i kept it. swore i'd get another and now have.
new one is an old one(model 5 from pictures i've seen for comparison). bought off ebay and near complete, my little 18 special needs love and time. wondering what i can and can't get if i need it and what easily transfers between models. the carb is now cleaned out and doesn't leak or flood but the O rings on the fuel [Censored] plunger are somewhat unhappy. are they a regular garden variety size/part?. the donk has good compression and looks presentable enough. one wheel is shot, the intake duct is long gone but i have a later convoluted type for now. paint is not an issue as it ain't a resto and i can live with unoriginality in most aspects if the benefit outweighs the wank value of all stock standard(doe's later leccie ignition transfer over, etc....). i'll likely never need to mow with it but want all functioning and looking presentable. i realize this is a vague set of questions, but will get some more specific queries for ya's as i get it into tiny pieces and work out whats wrong. will put a pic of the big girl up once i get settled in here.
just briefly, was there ever an actual trimmer produced to utilise the cast channel in the baseplate and where might i find a photo of one or the clip(?) that holds down my little plastic cover that is there in it's place.
thanks.
it runs!
new plug, clean carb, fresh fuel, wet and dry across the points and tingtititingtingting. pretty stoked.
Posts: 5,435 Likes: 36
engel, Hope that you found information on the board of some help. :Wavey: Great to see you got you mower and it would be good if you could post a picture on the board so people can see how it looks.
shall do. gotta get used to the girlfriends laptop first.
was there a trimmer?
the o-rings are now sealing. musta been that they were dry, but its stupidly stiff to open. any normal cure?
how does one upload a picture?
Victa Mower Specialist
engel, If you go to the help area of the board it has directions on how to upload a picture.
Victa Man
![[Linked Image from i172.photobucket.com]](http://i172.photobucket.com/albums/w10/engel_vh_CIT/vic2.jpg) my god! it worked. i'm a computer genius!
engel, Most parts are still available i.e. snorkel hose air filter spark plug points condenser "o"rings for fuel tap throttle cable fuel line wheels blade plate & blades. The Victa Special name plate that goes in the handle is expensive and hard to get. Technical Information is also available in the Parts list and manuals area.
got it in pieces now for the cleanup. wheels are off and i noticed the stub axles have really copped a pizzling through the years. is there a cure besides welding and grinding?
who sells the wheels please bruce and are they a good copy?
engel, If you go to the auction site OZtion and look for outdoorking you will see the wheels available. Just click this link button:
engel, I have seen the wheels that Bruce sells on OZtion and they are good quality. Here is a link to some that he is selling at the moment: Victa Wheels
Victa Man
they look good and all but the whole thing never cost me that much. reckon i'll cordially give em a miss for a fair while. are the odds of someone having "a" non buggered one that they've replaced somewhere collecting dust at a reasonable price. i'm not knocking the new ones as it costs a fair bit to tool up for small production runs, but i'm not a conoisseur and would happily live with a sound one that looks like crap. any takers?
righto kiddies. reckon the wheel thing is sorted out. new base is here too. let the fun begin!
engel,
When you get the mower finished I hope that you can post a picture of the finished mower as I would like to see it.
Victa Man
what thread is the flywheel nut? the rest intersperse with unc valiant bolts to replace what were missing but i couldn't match that one to make a puller.
engel, The thread type is 1/2" BSF. I have a friend that has a puller for the Victa Flywheel but he wants $20.00. Let me know and I will contact him.
i had used the blade holder nut, three 7/16 head val dash to column bolts and a series of broadening washers. may make a more permanent type later on if needed again but off once and on again was enough to get the points sorted. thanks for the offer. on another note, the handle bars were loose on the plate to tube bracket. i inserted some wet and dry between the clamp shells around the tube and it's doing the job for now. is there a preferred method?
engel, As far as the handle brackets go you have done what I would have done. Good to here that you are getting somewhere with the mower.
it's together again with the new base plate and will come to bits piece by piece for painting. room is at a bit of a premium in my shed and i'd preferif nothing got misplaced. is it normal for the link shaft to slide back and forth and out of the female square at the front? have i put it in backwards or is something missing?
Topics12,748
Posts106,774
Members18,085
