3 members (Dandare, bigted, Berniemac), 2,747 guests, and 287 robots.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
Early Morrison rotary mower
Shout Box
by Bruce - 16/03/26 08:10 AM
by geobee - 15/03/26 05:27 PM
Victa Super 24/600
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
Well the new belts have been fitted and I gave the mower a quick test run this morning. All went well and the only issue I have is how quick it moves. I've been a bit concerned about how the father in law would cope because the machine is heavier than expected and now it is a too quick - He is in his 70's. Figuring this might happen I picked up a Scott Bonnar Diplomat 590 for $50 yesterday. Also gave it a test run this morning. Has the expected drive problem which I knew but it cuts fine and the weight and control will be much better for him. I will start a new thread on the rebuild
If you just fit a 1/2" smaller pulley to the crankshaft, you'll slow down the forward movement without changing the cut quality (no change in ratio of cutter movement to forward movement). Depending on how much adjustment is available you may not even need a new V belt.
Of course you can still have fun with the Diplomat as well, no harm in having two mowers.
Was thinking it through as I mowed the front lawn ( with my rotary) after the test run out the back and figured a ratio change with the pulleys or sprockets was the answer. Went to load pic but it was too large and I cant resize on the phone. The small pulley for the drive belt is already pretty small and the guard on the larger pulley doesn't have the room to fit a bigger one. More thinking, measuring and calculating required to find the right ratio.
Here are a couple of pics of the new (old) Diplomat 590. [Linked Image]
Hi Diablo,
This is just a gentle heads-up mate, but this thread has wandered completely off topic which is: flywheel removal HK30....Can you please start a new thread for the Alroh pulley drive ratios HERE
Thanks mate. wink
I will now close this thread.If any member has anything to add, please PM a moderator.
Bowzie, Rowie_77, johnny rotten, SBColllector, JTB
17,880 Registered Users
Topics13,073
Posts107,317
Members17,880
PHP: 8.3.30 Page Time: 0.028s Queries: 25 (0.022s) Memory: 0.6456 MB (Peak: 0.6786 MB) Data Comp: Zlib Server Time: 2026-03-16 14:39:48 UTC
