1 members (Buckets), 6,618 guests, and 1,690 robots.
by nath - 16/10/26 10:48 AM
Hi
A friend who lives in the bush has a Greenfield Anniversary 12Hp 32� cut ride-on mower. I had a look at it for him as the belt squeels when he engages the cutters and continues to do so in heavy cutting. It seems the belt is a bit worse for wear and he should replace it. The belt is not tight when fully engaged. The engaging bracket is at the end of its movement.
I have looked on the site for some information to help with the job but so far nothing. If anyone could help we would be very happy. His model has an jack shaft at the front with the first belt driving to an upper pulley on the jackshaft and an idler which moves out to �engage� the cutter drive by tensioning the belt. The bottom jackshaft pulley then has a belt to drive back to some idler pulleys on the deck and then forward to the cutter shaft pulley.
The questions we would like to ask are;
1 does anyone have a diagram or parts listing for the belt arrangement on this model ?
2 any instructions or suggestions as to what has to be dismantled to change the first belt (is this called the engine belt ?)
3 what has to be adjusted when reassembling the belts. There is a bolt fitted to the rear of the jackshaft mounting which looks like an adjuster. Which belt does this adjust (if any) and how does it work.
Any assistance would be appreciated. I cannot supply any photos of it at this stage. Thanks jaahn.
PS What does the �Anniversary� relate to ??
Hi jaahn, welcome to Outdoorking.
Here is a badly scanned exploded view of the Anniversary 12-32 from the Illustrated Parts List, with the corresponding parts key:
I suggest you post photographs of the specific parts you are looking for details on, with references to the part names and numbers. That gives Outdoorking members the opportunity to explain things. If you don't post the pictures and details of your questions, it is possible that members will not take your questions seriously.
Thanks grumpy for the quick reply. smile
I cannot post pics at this stage as I am not there but I did find the complete parts list and I can see the bits on another page other than the one you pasted.It's pretty hard to read but I will study it and try to understand how the parts go together. It's on the engine page no 1.
Cheers jaahn grin
Abp5961, RossL, MartinWes, REG1, Ricko
18,166 Registered Users
Posts106,819
Members18,166
