809
2,540
Anonymous
I have a McCullough Mini Mac 35 which was given to me about 15 years ago. Tried to start it up for first time today. No spark. I am looking for a parts list/diagram so I can disassemble and clean and hopefully diagnose why there is no spark.
Any suggestions or parts lists or diagrams would be appreciated.
I registered as member mjm0103 but have not rec'd my password so I am sending this message as unregistered user mjm01032.
Posts: 5,436 Likes: 36
mjm0103, If you have not put in your correct email address you will not get your password. I have sent to you (using the email address quoted)your password. If you don't receive it send me your correct e-mail address by clicking on my name (moderator) and I will correct it. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Thanks, I'm not signed in as mjm0103. Any idea's on my mini mac?
Thanks Ken
Oops, I'm NOW signed in as mjm0103.
mjm0103, Parts list has been forwarded. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Thanks for the diagram of my MiniMac35. Helped a lot. Before disassembling, I was able to get it to fire (popped but didn't run) when I sprayed a little ether on it. I was able to get the saw apart. Cleaned the carb. Diaphram (pump) appeared soft/flexible. The gas filter appeared very gummed up, but seemed still porous. Couldn't pull the filter out of gas tank, worried I wouldn't get it back in. Installed a new spark plug. Set the hi and lo idle per instructions I saw on this site. After reassembling, filled it with fresh gas and tried to start it. It fired once for a second, then couldn't get it to fire again. Has great compression. I think it's a carb problem and not a condensor problem since it did fire (pop)...albeit one time.
I wouldn't mind replacing the gas filter if I could find one. Also wouldn't mind rebuilding the carb but not sure where to find a rebuild kit or they're even available.
I don't want to sink much into this since it could cost more to fix than buying a new one.
Do you know if rebuild kits/fuel filters are available? Approximate costs?
Other idea's on what could be wrong?
mjm0103, You should be able to get a carby kit from your lacal mower shop just take the carby so that they can supply the correct kit. As to the fuel filter I would leave it for now because it will be hard to get. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Topics12,755
Posts106,798
Members18,121
