1 members (MowingManiac), 860 guests, and 2,534 robots.
Sharing My New Lawn Mower
by ccxue - 21/09/26 07:18 PM
by FiM - 12/09/26 02:12 PM
by mower1 - 05/09/26 05:51 PM
by NormK - 12/09/26 07:48 PM
by NormK - 09/09/26 05:07 PM
#3363 07/01/07 03:58 PM
Hi
I have the above lawn mower and I have been having some problems with it.
For a start I got it off my brother as he had trouble and in the end bought a new mower. Though I would be smart and get it going.
When I got it home it had no spark, so I got a new one and then I had spark and it started and ran well, thought I had done well!
Next time I went to use it it stared well, then stopped 1/2 way through doing the lawn, no spark.
Talked to the local mower place and ended up taking the coil down and they checked it, said it was faulty and I replaced it. Again thought this was good and again mower started (didn't run really well)and got through 1/2 the lawn and it stopped. No spark again, bugger.
As far as I can see there is not much else it can be. I can see it has a small electronic box. I am also wondering if it has a cut off from the hand control which kills the spark, through the 2 wires going to the carby, which I do not understand at all.
Help please.
Regards
Andrew
#3364 07/01/07 04:44 PM
apjvicta,
Ok is the silver box loose?
If so you will need to replace the screw or pop rivet. Your problem could be a bad earth or the electronic module is faulty. confused
It is not very often that a coil goes it is usually the module and the replacement cost is about $30-00. :Wavey:
Also what you can do is remove one of the wires in the carby to see if you get spark back. yay
We have information on the carby and electrical under parts list and manuals area in this section. cheers2
#3365 07/01/07 05:07 PM
Thanks, Bruce
Silver box is not loose.
I previously took the carby off so 2 wires just dangling and no spark.
I will have a look in the manuals section so I understand a little better.
Failing that will replace the module.
Will let you know how I go.
Regards
Andrew
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
ccxue, Dreadman665, odderf, Tatzman, SeanClaude
18,121 Registered Users
Topics12,755
Posts106,798
Members18,121
