hello, I have an issue with this mower as thz "ZIP start" does no longer drive the motor shaft. Apparently the two alluminium "U" are worn out. How/ where can we find replacement parts? In belgium we can not locate and apparently according to the manufacture they are no longer available. Could you help, either with part specification, I can perhaps manufacture them myself, or with parts? Rgds Jimmy
------------------ Jimmy
Jimmy
more information on the subject from your link to documentation on "Straters four and two-cycle engines page 7 NOTE: ZIP STARTER MODELS" the worn part I refer to is the item 19. Rgds Jimmy
Jimmy
Posts: 5,434 Likes: 36
Jimmy, We can supply the parts but I would suggest that you replace item 24 as well because if the starter has been slipping I am sure that you have damaged the cup. Just e-mail us under spare parts and we will quote you the replacement price. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Thanks Bruce, I just logged a request for price quote for the parts. The nextquestion is I will have to clean, maintain the Carby, would you have documentation on the subject? The motor is a two cylinder version of the VC160. If I have to replace the Spark plug what model is currently the best, we have non laeded fuel here, the mixture fuel / oil what mixture would you recommend, oil quality etc..
Thanks again for prompt reply. Jimmy
Jimmy
Ooops, please read TWO CYCLE engine ....
Jimmy
jimmy, PLEASE READ1. Go to Victa Forum. 2. LOOK AT TOPICS. 3. You will see one on Carby's. 4. Click on topic. 5. Click on link for old carby's G3 Information will then come up on screen and you can print it. In reply to spark plugs I only use NGK. That model runs on a 25 to 1 ratio. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Thanks for all the good information. I shall now wait until the parts for the Zip starter have arrived and in the mean time I shall kleen the carby. By the way what is the best product to clean clogged carby and fuel lines / tank? Kind Regards Jimmy
Jimmy
jimmy, I use a product call carby cleaner you can get that sort of thing from your local car parts supplier but most people just use petrol and fine wire to clean the jets. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif) [This message has been edited by Bruce (edited 06 December 2005).]
Bruce,
We have a mail and posted a reply to you under spare parts: The subject is: the purchase of these parts item 19 (qty 2) and 24 (qty 1) of the Victa VC160 Zip Starter. at 25 AUD.
Please tell me how to proceed. As I shall need a reference for the quote to access the "trolley" and enter the payment, is it not?
More detailed information in per mail to SPARES and in the spares parts requests form
Best Regards Jimmy
Jimmy
jimmy, I have sent you information on how to purchase the items that you require. Thanks Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Bruce, just to let you know we placed the Po for the parts only... do not need the fiskar ratched pruner Best Regards Jimmy.
Jimmy
Bruce, With the carby doc you supplied I have now understood the principle of the governor and cleaned it. The moving contact part 27-28-29 were cleaned and reassembled and checked with for conductivity and non conductivity they are OK. after that I checked the magneto lead alone ( not connected to the switch) . Their seems to be an issue with it... In the carby section N figure N13 Model G3 governed Carburettor 1968-1972 version. When I check the cut-out lead comming from the magneto it is permanently in connection with the chassis ground. Is this correct?
If so how to access the magneto.. what caution to we have to take and so on ..
I am missing some documentation on this too. Regards Jimmy
Jimmy
High Bruce, I got everything checked with the documents I did found on the magneto on your site. The VC160 is again up and running and the first test will be with tree leaves... and in spring the first lawn.
Thanks for the profesionalism of yopur team , I shall recomend your group aroundme when they have issues that can't be solved locally.
I wich the whole group a happy Xmass and a Happy new year. Take care. Best regards Jimmy
Jimmy
Hi i must be stupid are the points under the flwheel,i have no spark.does the cut out have to be grounded graham email artist5@bigpond.com.au <font face="verdana,arial,helvetica" size="2">Originally posted by jimmy: Bruce, With the carby doc you supplied I have now understood the principle of the governor and cleaned it. The moving contact part 27-28-29 were cleaned and reassembled and checked with for conductivity and non conductivity they are OK. after that I checked the magneto lead alone ( not connected to the switch) . Their seems to be an issue with it... In the carby section N figure N13 Model G3 governed Carburettor 1968-1972 version. When I check the cut-out lead comming from the magneto it is permanently in connection with the chassis ground. Is this correct?
I am missing some documentation on this too. Regards Jimmy </font>
graham22, I will only be forwarding information to people that make donations to the board in future because of the cost of upkeep. So if you want to support our board to keep the information flow going I will email you the the information that you require. I am sorry for the inconvenience but because of the cost of the board we require support from our members from time to time Thank you for your understanding. Regards, Bruce ![[Linked Image]](https://www.outdoorking.com.au/board/biggrin.gif)
Topics12,747
Posts106,768
Members18,080
