782
2,511
I was given a victa 2 stroke mower, i'd like to identify it. It has no model badgeing on it and has a green plastic top deck. The catcher is secured by the hinged metal door on the rear catching a lip on the plastic rear catcher ( i dont have the catcher but my neighbour had the same model). It uses 25:1 fuel mix. I need blade part numbers. thanks
Posts: 5,436 Likes: 36
robbie d If you have a look at the air filter housing on the handle you will see the model number (where the bolt goes through the handle). That will help a lot as I need to tell you the correct blades. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
thanks willl check tonight
the model number is somewhat aged. the numbers i could get off it are AF05* AA9*
robbie d, The mower is a Pacer made between 1990 & 1992 and the model nuber is AF055 AA90. The blade type is a CA09306S bolt set is CA09277S. The catcher is GC11697A. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
thanks bruce. Replacing the blades should kill the vibration problem it has (i think the previous owner was mowing gravel). the next problem is the smoke, I know its a two stroke but this one smokes enough to fumigate a whole street. any places to check first? air filter, mixture?
Topics12,755
Posts106,798
Members18,121
