0 members (), 1,460 guests, and 1,006 robots.
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
Rover height adjust plate
by Bruce - 07/04/26 03:39 PM
YardKing 4 stroke spare parts
jms
Offline
hi have a homelite 2020 snipper that worked fine and then started with problems, It seems that it will not prime ie suck the fuel through when you pump the bulb, i have checked that the lines in the tank a connected which they are.
so when you push down bubbles come out in the fuel tank, then when you let let go you hear a sucking sound "air" bu t no fuel comes through to the primer bulb??
any ideas thanks jms
The primer should not pump air back to the fuel tank - it has a non-return valve to prevent that. It sounds as if you have a stuck inlet valve in the primer, or perhaps a suction air leak between the tank and the primer.
17,930 Registered Users
Topics13,086
Posts107,376
Members17,930
PHP: 8.3.30 Page Time: 0.034s Queries: 19 (0.028s) Memory: 0.6165 MB (Peak: 0.6335 MB) Data Comp: Zlib Server Time: 2026-04-25 08:50:29 UTC
