0 members (), 2,283 guests, and 710 robots.
by Bruce - 07/04/26 03:39 PM
Atom Spare Parts For Sale
by Bruce - 07/04/26 03:24 PM
Ryobi Spare Parts
by Bruce - 07/04/26 12:00 PM
by Bumps - 19/03/26 10:57 AM
Mower wheel ID.
Ryobi Spare Parts
Royal Enfield Mower
by Bruce - 05/04/26 03:47 PM
by Bumps - 01/04/26 04:37 PM
Mower wheel ID.
Eaton Model 6/7
#12217 18/05/09 06:44 AM
hi every one
i'm having trouble starting one of my suzuki mowers.you have to pull your guts out about twenty times and then it just might start.its got me beat, i've cleaned the carby,made sure the choke is getting full travel, fitted top and bottom seals.the spark is a bit on the dull side,but should be ok to fire it. the spark is constant, i've had worse at times and been ok. i havn't had a compression guage on it but it seems to have plenty when you turn it over. ive checked fuel flow,air cleaner etc. when it does eventualy start its as good as, i cant seem sort this one out except,strip it down and do the whole thing up, thanks micka
micka #12221 18/05/09 02:25 PM
Hi mika,
Have you checked weather it chokes fully or whether the flywheel key is sheared?, If its good I would think about checking the exhaust port and muffler for blockages. If all else fails I would start to look at the amount of fuel that�s getting thought, as it may be a simple blocked jet ect. I would think that the spark would be sufficient because it does fire and run after 20 pulls. Hope this helps
Regards jay
micka #12222 18/05/09 03:21 PM
Originally Posted by micka
hi every one
Have you checked the cylinder for damage? cheers2
Bruce #12223 18/05/09 04:02 PM
mowernut and bruce
after i fitted the new crank seals a while back it was starting good,but now its playing up again. i rekon its time to get a bit more serious and check out the cylinder,piston and ring department. i'll let you know whats happening thanks micka
micka #12224 19/05/09 01:29 AM
micka,
If you have movement in the crankshaft the seals will be gone again. It is easy to check if the bearings are worn by just holding the blade plate and see if you have any sideways movement. If so replace the bearings and I would also replace the rings at the same time.
We will have a kit in the online store soon so keep a look out because we are updating all the time with new products as request are made. cheers2
17,924 Registered Users
Topics13,080
Posts107,356
Members17,924
PHP: 8.3.30 Page Time: 0.044s Queries: 26 (0.038s) Memory: 0.6372 MB (Peak: 0.6708 MB) Data Comp: Zlib Server Time: 2026-04-16 10:17:34 UTC
