1 members (Nick James), 736 guests, and 498 robots.
by mm-mowers - 26/12/25 04:47 PM
Warning re increasing speed
by peterklos - 26/12/25 04:45 PM
Lth2142 vibration stumped
by peterklos - 26/12/25 04:34 PM
Frame ID please
Victa full crank edger
by NormK - 24/12/25 02:51 PM
by AMP - 24/12/25 09:29 AM
by DDD - 19/12/25 06:12 PM
by peterklos - 26/12/25 08:50 PM
by NormK - 26/12/25 08:43 PM
by NormK - 26/12/25 05:39 PM
Frame ID please
Rover Victa ROVIC Mower
Star Poducts cylinder mower
by DDD - 21/12/25 01:15 PM
Hi I have a husqvana lth2142 drives ok soon as I engage the cutter the motor vibrates badly .
Have replaced all the bearings on the deck , new belt , blades are new and checked balance.
Engine bolts are tight PTO looks ok .
Motor runs at normal RPMs
Any ideas don’t know what else to look for.
Stumped !
It is a blade balance problem. Remove the cutter belt and then run the motor and engage the PTO, should get no vibration
Thanks blades are new and have checked each blade for balance , have run the mower with no blades and motor still vibrating.
Just don’t know what to look for next
So you say the vibration occurs when you engage the cutter then I'm thinking bent shaft. Remove the PTO and run it again or put a dial indicator on the shaft and with the plugs out rotate the motor slowly and check the runout. There is a degree of vibration when the cutter is engaged because there is a lot of bits hammering around, but you will have to check the crank for runout
Thanks good suggestion , looks like Thats the only thing left , I will remove the PTO and put on a dial gauge with plug removed as you suggested
SADiplomat, Greggor, Djelli, undead_raven, frmtrkr
17,742 Registered Users
Topics13,042
Posts107,156
Members17,742
PHP: 8.3.27 Page Time: 0.027s Queries: 24 (0.021s) Memory: 0.6355 MB (Peak: 0.6671 MB) Data Comp: Zlib Server Time: 2025-12-26 11:59:46 UTC
